Delphi replacement with aftermarket system?
Discussion in 'Ask An Owner Operator' started by Paul871, Dec 22, 2022.
  1. Paul871
    Paul871 Bobtail Member
    17
    15
    Jun 5, 2021
    Has anyone replaced the Delphi head unit and touchscreen with an aftermarket system? and can you just rip it out and put the new unit in? Because the Delphi 601 has the digital gauge system with it which I rarely use if ever and to be honest it's got to be the biggest pile of cap ever made, and I just wanna get it out of my truck and install a Kenwood or Alpine... But I don't wanna just rip it out and find out all of a sudden that something isn't working properly.
    Any info would be gratefully appreciated.
  3. Long FLD
    Long FLD Road Train Member
    12,835
    53,709
    Mar 4, 2015
    I’m just guessing that it won’t be a simple remove and replace because the factory unit is probably tied into the cab control module. But I could be wrong and it wouldn’t be the first time.
  4. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    Type of truck...?
    Rideandrepair Thanks this.
  5. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    Looks like a newer W9, in his profile pic.
    There’s a certain level of integration, as my T680 has reverse mute. However, it may just be a feed from a module/sensor to the deck. I highly doubt there’s any “brain” in the deck feeding the BCM with relevant info. It’s gotta’ be a one-way deal.
    I had a motorhome with the deck being integrated into the camera system. When I upgraded the stereo, the shop went straight into the wire harness and utilized only what feeds they needed to give me the reduced level of integration I wanted. I had them remove the reverse mute and eliminate the mirror camera feeds. It didn’t affect the chassis, as it’s not relying on the stereo for any type of signals. Again, just a one-way deal.
    Rideandrepair and Bean Jr. Thank this.
  6. Paul871
    17
    15
    Jun 5, 2021
    W900L
  7. Paul871
    17
    15
    Jun 5, 2021
  8. Paul871
    17
    15
    Jun 5, 2021
    Might have to talk to Kenworth and see if they have anything to say. Appreciate the input guys.
    Rideandrepair and ducnut Thank this.
  9. ducnut
    2,683
    8,131
    Dec 31, 2010
    SPI
    I’d venture to say you’ll have better luck at a car stereo shop. These decks have a pretty similar commonality in their wiring harnesses. When the shop pulled my motorhome deck, the installer started telling me what every wire did. He said, for the most part, they’re all the same. A truck dealership isn’t going to have that kind of knowledge, as they just don’t do that type of thing, everyday. Plus, if you’re at a shop and they recognize the KW harness, they can probably take care of you with a new deck, while you wait. Just be done with it in one shot.
  10. MacLean
    MacLean Road Train Member
    1,380
    4,090
    Sep 12, 2017
    Check with a stereo shop. If lucky Pac or Metra might have an interface module to make it work. If not… Gut everything and start new.
  11. Paul871
    17
    15
    Jun 5, 2021
    Ya I agree I think that's the best approach. Then at least I'll have piece of mind knowing it's done correctly.
    Thanks boys.
