Derate for automatic Cascadia solution?
Discussion in 'Ask An Owner Operator' started by Regional, May 25, 2025.
  1. Regional
    Regional Light Load Member
    242
    45
    Apr 4, 2020
    I have an automatic Cascadia 2020. Does anyone know how to bypass a 5mph derate? Some people are saying to remove the ABS fuse and speed sensor on transmission and then drive in manual mode. I’m not sure if this works. I would appreciate any knowledge and insight on this topic.
  3. 062
    062 Road Train Member
    6,324
    33,960
    Oct 20, 2013
    If it’s a DT12 transmission it should work just unplugging the speed sensor.
    If it is a Allison it will up shift, but it won’t down shift and you’ll need a transmission.
  4. Regional
    242
    45
    Apr 4, 2020
    Yeah it’s a DT12 automatic. I’ve heard from others that this doesn’t work. Have you tried this?
  5. 062
    6,324
    33,960
    Oct 20, 2013
    Yes, I don’t remember the year model, but it was in the neighborhood.
    It was to get to a safe place to work on it 6-7 miles.
    Turn the truck off and get out of the truck,let all the modules close, then unplug the speed sensor.
    You’ll know if it works when you start to take off all the lights should go out.
  6. DannyB
    DannyB Medium Load Member
    353
    670
    Apr 13, 2008
    Jackson Mi
    I know. I'm a dinosaur. My best advice? Throw the autoshift in the scrapyard and put in a manual 13 speed. In the long run, you'll save money.
  7. engine_900
    engine_900 Bobtail Member
    20
    22
    Jul 16, 2021
    Vancouver, BC
    +1 this. 2022 winter I got derate at a far-away town in Northern BC. Unplugged the speed sensor and drove 700miles with no big issue other than capped 1000rpm and no engine brake.
    FloridaRetired Thanks this.
