Detroit 60 issues
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Spacedout, Mar 1, 2024.
  1. Spacedout
    Spacedout Bobtail Member
    5
    Long time lurker, first time posting new member.
    Ive got a 2010 Freightliner with a Detroit 60 series with the first gen non-def dpf.
    Ive put alot of money in this thing and the problem continues. Once it warms up past 125 degrees it starts loping and surging at idle and under a load. It gets to the point its undriveable. Heres what ive done so far:
    New ecm
    New left side harness
    New injector harness
    New intake throttle valve
    New egr and sensor
    New intake temp sensor
    New dpf harness and sensors
    Cleaned and tested dpf filter
    Cleaned doser valve
    Replaced accelerator pedal
    Not sure what else to look for. I pay for a forced regen at the local FL shop and i get a few decent days, then it goes back to the same issue.
    Ill include a link to a video i did of the issue:
    Thanks
  3. 062
    062 Road Train Member
    6,309
    33,925
    Oct 20, 2013
  4. QUALITYTRUCK
    1,817
    1,783
    Jun 14, 2009
    romulus,mi
    Kind of hard to get full story with video. Want to verify couple of things. (1) early in video "ECU 128" displayed in message center. Check engine light usually on with that message. Is CEL burnt out on dash? Has it been plugged in with DDDL yet? (2) later on in video is RPM fluctuating like that by itself or are you on pedal reving?
    062 Thanks this.
  5. Spacedout
    5
    That code means there is a code but FL says theres not really a code. CEL works fine. That at the end is me slowly bringing it up to 1500 rpms steadily like i did when it was below 130 degrees. Its like its like im revinging it but im not, just slowly pushing down the accelerator.
  6. QUALITYTRUCK
    1,817
    1,783
    Jun 14, 2009
    romulus,mi
    Don't know what "That code means there is a code but FL says there's not really a code" really means. In order to help narrow down an issue you are going to have to go somewhere that is proficient with DDDL. Too many possibilities with the info. that you have given. Why a FL dealer is having an issue with this is beyond me.
    062 Thanks this.
  7. Spacedout
    5
    Everytime i take it in it costs me about $4000 and i get it back running good, then a few days later its back to this. Our FL shop just isnt working for me. The next FL shop is several hundred miles away. No other shop in this area wants to work on it.
  8. Brandt
    Brandt Road Train Member
    4,616
    6,343
    Sep 17, 2012
    You could take it to a Detroit Diesel shop or if you ever go to Pennsylvania Pittsburgh Power claim they can fix truck other can’t.
    One of the problems they had when DPF was first put on trucks. The DPF filter was clogging from my understanding. What we know now the S60 engine and all those engines at that time, were not running hot enough to keep the DPF hot when driving down the road and keep them clean.
    One of the reasons the newer engines run hotter today is to keep the exhaust hotter and keep the DPF working when driving and not needing a parked regen.
    I’m just guess that could be your problem because you said truck if fine after dealer does parked regen it good for a couple days. Pittsburgh Power sells additive to help diesel run hotter. It really for the newer truck not sure if it can get S60 exhaust hot enough to keep DPF filter clean or not
    Pittsburg Power might have a better ecm tune to help those first generation DPF trucks
  9. DDguy
    DDguy Light Load Member
    157
    101
    Apr 21, 2020
    Ont. Canada
    Is this a DDEC6 Engine ?
  10. Spacedout
    5
    I believe it is
  11. Spacedout
    5
    Good info, ill start looking into that additive, couldnt hurt!
