detroit diesel code 54 help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Nov 26, 2015.
  1. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    my 1996 kw t600b logged code 54 today and the truck has lost power it struggles to rev to 1500 rpm when it use to rev to 2300rpm. any hep from you detroit guru's will be greatly appriciated.
  3. 062
    062 Road Train Member
    6,319
    33,952
    Oct 20, 2013
    From what I read that's vehicle speed sensor. So check wiring and sensor.
    truckerbangin Thanks this.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    54 is a vehicle speed sensor fault. Could be a bad sensor, but more likely a wiring issue. Your engine has gone into anti-tamper mode because it's not getting a speed signal.
  5. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Ya, speed sensor. If the computer cannot tell how fast the engine is going it can't set the flow rate for the injectors and that's why it runs rough. It's an easy fix for any shop to do and should be a pretty cheap fix.
  6. truckerbangin
    268
    45
    Jan 22, 2013
    changed speed sensor yesterday and it still was derated. came back this am to troubleshoot the issue and truck was back to normal.
  7. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    Sounds like you have an intermittent connection. Check for chaffed wires, loose or corroded pins in plugs,
    truckerbangin and Skate-Board Thank this.
  8. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Can you set your engine on high idle to a point where it runs rough? If so, start wiggling the wires and see if the problem comes and goes.
  9. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Also, did you set the depth correct on the sensor?
  10. truckerbangin
    268
    45
    Jan 22, 2013
    yeah i set the depth of the sensor right. truck ran fine all day friday and saturday. i'd like to figure out why my gauges are slow to respond or off
