hey guys i have a 3 codes on my s60 that i could use help with
truck is a 2007 freightliner century 14L
codes are as follows
1. eng high 128 411 00
2. eng calib 128 411 13
3. eng errat 128s 146 02
if you coule help would be great
detroit s60 chips
Discussion in 'Freightliner Forum' started by damutt, Jul 13, 2015.
The first 2 are EGR Delta Pressure Sensor Faults, 00 is out of range high, 13 is out of calibration. The first thing I'd check is that the tubes are clean and connected properly. Could be a failed sensor.
146 has to do with the EGR valve. Erratic signal could be from many things. It could be due to the other faults. I've seen EGR leaks set that fault, as well as bad electrical connections. -
Awsome thanks. Would those cause crappie fuel milage ad well.truck dies have 836xxx miles if that helps any.
Do I need any special tools to remove the egr tube to check it?
Sorry for the stupid questions in the process if buying truck from owner, if tube is dirty do do I clean it, how long does truck have to be off before I can pull tube off without burning myselfLast edited: Jul 14, 2015
Reason for edit: More info,questions -
I got the same problem on my truck ENG HIGH 128 411 00 , what is that?
