diesel fuel help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by slowhandpete, Feb 3, 2013.
  1. slowhandpete
    slowhandpete Bobtail Member
    48
    12
    Jun 18, 2011
    salem,in
    does anybody havee any home cures for thiss new crappy diesel fuel, any good lubes that do not cost an arm and a leg.
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    I buy Lucas upper cylinder lube and use it. Cheaper to get it from the local guy here by the case than in the truckstop.
    Try to buy your fuel in states that don't have bio-diesel added in for now. I see my filters plugging up a lot faster when I use more biodiesel fuels. MN is back for that, ND, not so much.
  4. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    I don't have any problems except lower mpg with the bio-blends. Doesn't justify spending over $20 for some magic snake oil each fill up.
    Get yourself a good filtration system.
    Davidlee Thanks this.
  5. Diesel Dave
    9,640
    32,555
    Jan 20, 2010
    Hesperia, Ca.
    Go to Walmart and buy a gallon of 2 stroke oil. 1/2 oz of 2 stroke oil per a gallon of fuel is recommened. FYI, we know they have remove alot of sulfer from the fuel BUT the refineries replace it with more ASH for lubrication. But I still use 2 stroke or marvels mystery oil( be warned its red so dont use so much). In the old days cheap transmission fluid is what I used on a cummins and even tried it on my E CAT engine with no problems but stop using it after reading here the down side on electronic injectors.
  6. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    What ever happened to the $1/bottle cheapo tranny fluid in the tank every 2 or 3 tanks to clean everything out. I usually sump a bottle of that in when i fuel and call it good about every 3rd tank hasnt hurt anything yet but with what im saving over lucas i figure if it does hurt something down the line i can afford to fix it with the money im saving.
  7. d o g
    d o g Trucker Forum STAFF Staff Member
    24,713
    54,302
    Sep 20, 2010
    Texas
    The big thing that hurts the transmission fluid is the color.
