Difference in 13 speeds?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Mar 11, 2020.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,415
    1,738
    Dec 4, 2019
    ‘77 IH 4070 has a 12513 transmission and my ‘93 W9 has a 15613. What’s the difference?
  3. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Torque rating 12 for 1250 ft/lbs and 15 for 1550 ft/lbs I believe
    mile marker 27 Thanks this.
  4. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
  5. SmallPackage
    5,777
    18,546
    Dec 20, 2019
    Marion Texas
    Along with what @magoo68 said. They shift differently. 12513’s cannot be pre selected for the splits when you upshift to another hole. You post select for up shifts.
    Example. 7od to 8 dir. leave it in od go to 8 and then select to dir.
    You pre select splits on down shift of holes.
    Example. 8 dir to 7od. Select od than shift to 7 hole. Kinda hard to explain without showing you.
    You do pre select for the range changes up and down as normal.
    They also sing to you at about 60-65 mph in od. Not as bad as the 9513’s but they do have a whine.
    Dino soar, Brettj3876, swaan and 2 others Thank this.
  6. SmallPackage
    5,777
    18,546
    Dec 20, 2019
    Marion Texas
    They are a tough trans they put them behind the big power of the day. 475 cummins. 425 1693 and V8 Cats. And KTA cummins. There are still a lot of them running with millions of miles on them today.
  7. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    That kinda makes me wonder if my post on how to put the old style 3 position shift knob, like on my 12513 on my 15613, that’s in my ‘93. Nobody has responded to a few questions I had.
    650cat425 Thanks this.
  8. SmallPackage
    5,777
    18,546
    Dec 20, 2019
    Marion Texas
    I thought in that one I told ya how to do it.
  9. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    This guy gets it. Exactly what i tried explaining recently about splitting my RTOO9513. And yes it whines like hell with a .62top gear. But the truck will do 80mph with 4.78 rear
    SmallPackage Thanks this.
  10. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    What he said. That's how i shift our old .62 double. They get hot when you constantly lug em so don't do that. Im in love with it on 22.5 LP and 3.91/ 1600 is sweet spot on the 93. 75mph in last split and 65 in what most call direct (.73 on this one)
  11. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I wonder why on the 12513 transmission that you can pre-select the split when you downshift to a lower gear, but you can't pre-select the split when you shift into a higher gear.
    I wonder why mechanically you can't do that.
