Difference in rear rating
Discussion in 'Ask An Owner Operator' started by Swift09, Nov 29, 2019.
  1. Swift09
    Swift09 Light Load Member
    77
    106
    Jul 4, 2019
    What are the technical differences in 36, 38, and 40k rears? What performance differences would you see in running primarily flat midwest states? Thank you
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I have 46,000 lbs rear ends.
    The various sizes have heavier components and heavier axle housings.
    For example, a standard axle may have a 9.5 mm housing thickness, a super 40 can have an 11 mm thick axle housing and my 46's have a 12.7 mm thick housing. Of course there is a significant weight difference as you go up in capacity.
    Some have reported that the thinner housings can flex under heavy loads, causing tire wear.
  4. AModelCat
    164,449
    Heavier housings, heavier duty gears inside.
  5. Dino soar
    Dino soar Road Train Member
    4,815
    27,070
    Dec 8, 2017
    I thought everything is heavier.
    Heavier axles, heavier gears, heavier bearings, even larger brake shoes.
    And everything is more expensive.
    uncleal13 Thanks this.
  6. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    Id suspect all components larger, thicker, heavier and with more bolts or bigger bolts. Bigger bearings and brakes.
  7. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    My rear is too big.
