Differential mileage question.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mr79W900A, Mar 14, 2024.
  1. Mr79W900A
    Mr79W900A Light Load Member
    120
    72
    Mar 4, 2019
    British Columbia
    Hey guys I’m looking at swapping out my walking beam for an airliner air leaf with some meritor rt-46-160p diffs. My question is they have around 800k miles on them. What’s considered high miles for diffs. Thanks
  3. Lazer
    Lazer Road Train Member
    1,848
    2,978
    Jan 22, 2017
    If reasonably maintained, ie; full synthetic gear oil since new, kept topped off, changed at recommended intervals etc., a differential should last the life of the truck.
    Mr79W900A, W923 and beastr123 Thank this.
  4. beastr123
    beastr123 Road Train Member
    2,947
    24,178
    Jan 2, 2014
    Moose Jaw SK CAN
    wheel ends and input/thruput seals may need attention but if serviced regularly the center sections should last almost indefinitely. Fresh synthetic lube at 100k mile (160km) intervals is a great plan.
    Mr79W900A and Diesel Dave Thank this.
  5. SmallPackage
    5,774
    18,532
    Dec 20, 2019
    Marion Texas
    I’ve seen many 50-70 year old trucks with their original rears. Some probably never got serviced much. My original ‘67 Rockwell 4.33 SQHD’s had 4.11’s put in them in 1992. Up until 2003 they pulled the rockies up into Montana from south Tejas weekly. 1,689,347 miles later they still doing good.
    Mr79W900A and W923 Thank this.
  6. W923
    W923 Road Train Member
    1,419
    4,387
    Feb 28, 2022
    True or false, I don’t know but I had a gear shop tell me that the 23/46-160 is nearly indestructible. The guy claimed they work on a very low percentage of them even considering that they are typically used in rough service applications. I said no surprise they’re so outnumbered by regular road axles and he seemed to think they still worked on a disproportionate low number. i have a couple trucks with 46-160 axles and the drive components are much heavier built. They still have the same places to leak oil as the rest and that will kill anything when it gets run out of oil. Bottom line they could easily last a million or two if they are maintained or much less if not.
  7. W923
    1,419
    4,387
    Feb 28, 2022
    Make sure you get full lockers…then you will have similar mobility to the walking beam with only a power divider lock
  8. Diesel Dave
    9,613
    32,330
    Jan 20, 2010
    Hesperia, Ca.
    100k ? Thought it would go way longer. ;):rolleyes:
    Last Call Thanks this.
  9. AModelCat
    164,449
    Depends a lot on the application.
    Believe it or not a reman component could very well have gears in it that are on their 3rd life. A manufacturer of yellow iron would have us etch the rebuild number (1st and 2nd) along with component hours at each overhaul. At 3rd rebuild the gears were tossed regardless of condition.
    Long story short, the gears themselves have a pretty long and reliable life if they aren't shock loaded and oil is kept clean.
    Diesel Dave Thanks this.
  10. beastr123
    2,947
    24,178
    Jan 2, 2014
    Moose Jaw SK CAN
    Chances are considering his location I gave him the "safe" (2 to 3 times) recommended service interval for severe service. Pulling 140K up and down 8 to 10% grades in BC almost daily qualifies.
  11. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    My Volvo diffs have 1,400k. Bearings at 1,100k and a few wheel seals
