Differential troubles
Discussion in 'Trucks [ Eighteen Wheelers ]' started by masteron, Nov 2, 2023.
  1. masteron
    masteron Bobtail Member
    32
    14
    Feb 14, 2022
    Hi
    Just got a truck at an auction, 1995 international 9400
    Got it up and running, hooked up the air to the power divider
    and the diff seized, had tow the truck, broke the pinon gear, crown and satellite gears on the front diff
    changed everything, got it up and running, and seized again
    This happened to the sat gears now[​IMG]
    <a href='378f4b99 3568 416d b05f ea6207099755 — Postimages' target='_blank'><img src='378f4b99 3568 416d b05f ea6207099755 — Postimages' border='0' alt='378f4b99-3568-416d-b05f-ea6207099755'/></a>
    Any ideas ?
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Sounds like something isn't turning in the driveline after the front input and causing it to break. Put the axles up on jack stands and see what turns by hand and go from there.
  4. masteron
    32
    14
    Feb 14, 2022
    So past owner had 9/39 front 14/41 rears, found the culprit
    skallagrime Thanks this.
  5. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Thats quite special, hope your price was dirt cheap, 2 sets of rears isnt
  6. masteron
    32
    14
    Feb 14, 2022
    Thank god it was almost gifted
  7. SmallPackage
    5,777
    18,542
    Dec 20, 2019
    Marion Texas
    So one is a 2.92 and the other is a 4.33? They must of just scrounged some centers up and threw them in to sell it. Just pull the interaxle drive shaft (jack shaft) and lock in the power divider. Should drive like a single screw to get it were you need to fix it.
  8. masteron
    32
    14
    Feb 14, 2022
    It was working, moving containers in a truck patio
    The mechanic cut the air to the interlock and called it a day
    We towed it back to our patio with another truck, now working on the rear dif, but can not get the new ring and pinon to match, guess they changed something else
  9. Deezl Smoke
    Deezl Smoke Medium Load Member
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    The ring carrier has a ratio range limit.
    masteron Thanks this.
  10. masteron
    32
    14
    Feb 14, 2022
    Thanks ! So now on to find a carrier or machine a spacer
  11. Deezl Smoke
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    So keeping in mind that I am not an educated engineer, just an old hack that's failed too many times, I'd do everything possible to not use a spacer.
    Reason?: The gear is hobbed from an alloy blend that allows for proper hardening post machining. Usually a form of "case" hardening which is why the hardened gear face can flake off. The carrier is cast from specific metallurgy to accept machining for the bearings and spider poles etc., also to accept the extreme side loading of the pinion trying to repel the ring gear. < is why I would not run a spacer. Each, the carrier and the ring gear are made to expand and contract at near equal rates with temperature. So you have just one mating surface to set the lash proper. If you insert a spacer machined from non-like metals, you now have 2 mating surfaces and the spacer holes ad length to the bolts, which allows more bolt stretch, and under extreme torque input of the pinion, 2 mating surfaces ads twice the opportunity for mating surface slippage.
    A proper carrier ratio range should be available for both rotations (the reverse rotation of the power divider head, and the rotation of the rear end), or at minimum for rare model, one end or the other.
    There's a place in Washington state "Inland gear" that I have used for rare hard to find stuff.
