Difficult question for seasoned drivers
Discussion in 'Hazmat Trucking Forum' started by NewBeginnings81, Mar 17, 2025.
  1. NewBeginnings81
    NewBeginnings81 Bobtail Member
    Hi, apologizes if this is in the wrong section or an commonly asked question.
    Do CDL hazmat companies even consider hiring driver with expunged criminal records and also already have Hazmat endorsements?
  3. MACK E-6
    49,993
    237,960
    It depends. Some might want to run a background check but that shouldn’t be a huge impediment, especially if you already have the endorsement.
  4. lual
    lual Road Train Member
    5,316
    9,693
    Oct 22, 2020
    SW Georgia
    It depends on:
    • Where you live
    • How much/what type(s) of experience you already have (if any)
    • The freight market (or the lack thereof) in your area
    • The carrier(s) in question -- & their hiring criteria & methods
    • The type(s) of freight you are considering
    -- L
    Lav-25 Thanks this.
  5. RockinChair
    RockinChair Road Train Member
    5,353
    14,277
    Feb 19, 2012
    Lubbock, TX & thereabouts
    If the record has been expunged then the applicant's case(s) shouldn't show up on the background check, right? I'm under the impression that only the courts and DoD can access cases that have been expunged or sealed.
  6. Chinatown
    Chinatown Road Train Member
    77,710
    184,206
    Aug 28, 2011
    Henderson, NV & Orient
    Most will hire you.
    MidwestResident and The_vett Thank this.
  7. tscottme
    tscottme Road Train Member
    There is no one rule. It varies by company.
  8. 18WheelerHustle
    18WheelerHustle Bobtail Member
    23
    44
    Mar 21, 2025
    There are many companies that do not do a criminal background check on truckers even for HAZMAT
    wis bang Thanks this.
  9. cobra7479
    cobra7479 Light Load Member
    All companies do some sort of background check, 3,5,7 and 10 year seem the most common. Small O/O companies might just do MVR check to hire you. The criminal background check is to protect the company from liability and lawsuits.
  10. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,956
    Oct 31, 2023
    If your record is clean enough to pass the BG for HAZMAT you shouldn't have any problems with an employer. Also, if a record is expunged you don't have to tell them and they have no way of finding since it's essentially erased.
  11. Someguywithquestions
    Someguywithquestions Medium Load Member
    407
    668
    Jan 10, 2021
    We had a guy once get approved, put in 2 weeks at his current employer then corporate found an expunged marijuana conviction when the guy was a teenager from 20-30 years ago. Corporate declined his job offer. This was at a big LTL carrier.
    Even though it was expunged, it was still uncovered. The background checks they did were some of the most invasive I've ever seen.
