Direct Tiedown Question
Discussion in 'Flatbed Trucking Forum' started by thomasweil, Sep 27, 2017.
  1. thomasweil
    thomasweil Bobtail Member
    11
    5
    May 12, 2016
    Just a question on math. The image is from J.J. Keller. Why not state it as this:
    35,000/4=8750
    In other words, don't halve the weight of the loader and don't halve the WLL of the chains. Why do the extra steps?
  3. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Because that's the way it's determined by the fmcsa.
    Don't ask why the government does things the way they do.
    Orangees and norb5150 Thank this.
  4. thomasweil
    11
    5
    May 12, 2016
    Okay no reason for it, so one can assume WLL for indirect is 50% and WLL for direct is a 100% and I can skip all the math. Thanks.
  5. kylefitzy
    kylefitzy Road Train Member
    4,752
    19,799
    Aug 12, 2007
    Kansas city,Mo
    Just the opposite. Wll for direct is halfed.
    TPS Report Thanks this.
  6. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    Because if you throw an indirect tie down in the mix it is not halved but the requirement is halved still. Easiest to explain the rules to cover both scenarios.
  7. Espressolane
    18,673
    117,014
    So the chain has been determined, and based on the size of chain used, this number will move around.
    The one thing missing is that WLL is determined by the lowest rated component in the tie down sysytem.
    attachment locations, binders, hooks and clevis all play into the rating.
    Orangees Thanks this.
