Do i need a cdl?
Discussion in 'Questions From New Drivers' started by artvandalay, Jul 5, 2020.
  1. artvandalay
    artvandalay Bobtail Member
    5
    I currently have my cdl a for > 26000 and combination vehicle. If I wanted to buy a medium duty truck without airbrakes and use a fifth wheel trailer, would I need to have more restrictions removed?
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    no, just drive.
    you do not want to "remove" something off your current CDL-A, unless you had an automatic restriction, and then you'd need a road test in a manual trans truck. so that you can then drive manual trans trucks.
    artvandalay Thanks this.
  4. singlescrewshaker
    4,852
    42,408
    Dec 31, 2017
    Little Havana, FL
    Am I reading this right..
    You have a CDL A for less than 26,001 lbs.?
    How is that even possible. My understanding of class A is combination greater than 26,001lb, while towing a trailer over 10,001lbs..
    AModelCat Thanks this.
  5. Espressolane
    18,665
    116,948
    OK, it was not just me. Said nothing about restrictions.
    singlescrewshaker Thanks this.
  6. artvandalay
    5
    I've been out of school for awhile, but I was always taught ">" was greater than. If I'm wrong Ill delete my account and never post here again.
  7. Scoot 1971
    Scoot 1971 Light Load Member
    265
    348
    Nov 22, 2018
    The " greater than and less than" symbols point in opposite directions. If the pointed end is facing the #, it is less than. If the open end is pointed at the #, it is greater than.
    Of course the symbol should always be in front of the # or value. So , > in front of, or to the left of # is lesser than. <, would be greater than. Most folks get this wrong.
  8. Bakari742
    Bakari742 Road Train Member
    1,325
    906
    Jan 30, 2016
    United States
    I’m sooooo confused. The OP was right though
  9. Moose1958
    Moose1958 Road Train Member
    15,290
    33,957
    Dec 17, 2010
    Williesburg, Virignia
    You are not providing enough information. One piece of information I need is what restrictions do you currently have? Air brake? Automatic Transmission? Intrastate only? etc! The planned size and weight of that trailer would also help.
  10. Concorde
    Concorde Road Train Member
    5,472
    19,382
    Jun 29, 2016
    West Melbourne Florida
    Sounds like OP has a CDL B...never mind.. I got confused also.
    back to my morning coffee
  11. Grumppy
    3,233
    11,401
    Dec 11, 2010
    West Monroe, La
    If you have a class A, keep it. Just because its not required, doesnt mean you cant have it. In other words, just because your between jobs for example, doesnt mean you have to give up a class A to drive a car. With any class licence, you can drive anything UP TO & including that class vehicle.
    So, keep the class A & drive the smaller truck. Then if you ever want to go back to a class A, you dont have to change anything or go re-test etc to get your class A back.
    kemosabi49 and Truckermania Thank this.
