Do straight trucks pull trailers?
Discussion in 'LTL and Local Delivery Trucking Forum' started by Ddr1992 579, Sep 26, 2019.
  1. Ddr1992 579
    Ddr1992 579 Medium Load Member
    395
    100
    Sep 10, 2018
    Would it qualify for a class a cdl for a 26k gvw ihc durastar with a loaded tandem axle cargo trailer weighing about 19k pounds?
    Mike2633 Thanks this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    Combination vehicle. Yes.
  4. Mike2633
    Mike2633 Road Train Member
    6,461
    25,990
    Jun 14, 2013
    At Home on The West Side
    Any trailer over 10K needs a class A cdl.
    Dino soar, Tb0n3 and FlaSwampRat Thank this.
  5. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,356
    Nov 1, 2017
    The Sticks, Idaho
    In Idaho if you use that setup to get a Class A CDL you get a restriction on your license that says you CANNOT pull a standard 5th wheel style trailer. So you would be stuck with straight truck and pup style trailer... No traditional tractor trailer. Idaho started this in 2015 or 2016 I believe.
    Matt1924, x1Heavy, road_runner and 5 others Thank this.
  6. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    x1Heavy, clausland, D.Tibbitt and 3 others Thank this.
  7. mud23609
    mud23609 Medium Load Member
    652
    1,444
    Mar 9, 2015
    Only if the truck is over 26k or if the combined weight exceeds 26k
    9900 pound truck and 14k trailer equals no cdl. Under federal rules.
  8. D.Tibbitt
    156,674
    See it all the time with fuel haulers. Straight truck and pulling tanker behind straight truck. Also with dump trucks
  9. stayinback
    stayinback Road Train Member
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    It is more work than it has to be-
    With that setup- Now you need 2 sources of power in breakdown- A tractor to move that puppy
    I just assume 1 truck 2 trailers....
    Kinda like 2 girls 1 ...........What was that?!?!!
