Does CDL testing info transfer from state to state?
Discussion in 'Questions From New Drivers' started by bluejet, Oct 16, 2016.
  1. bluejet
    bluejet Light Load Member
    67
    20
    Nov 8, 2014
    I went to a CDL mill school in Georgia and passed pretrip and backing, but I failed the road test. Unfortuantely, this school only gives you 2 tries to pass. I am looking to go to another school in Utah and am wondering if I go to a CDL mill school there, will I have to take pretrip and backing all over again, or will I just have to do the road test?
  3. TROOPER to TRUCKER
    TROOPER to TRUCKER Anything Is Possible
    7,678
    12,754
    Dec 15, 2014
    Charlotte, NC
    Yeah it's all or nothing best bet is to try Millis Transfer only a small up front but the best cdl company and once you are through training you cane get home every weekend.
    Nomatter where you go it's starting over but if you passed it once another should be no problem.
    CallOfTheWild Thanks this.
  4. bluejet
    67
    20
    Nov 8, 2014
    well that sucks. I'd rather not do pretrip and backing all over again. Hell, I'd rather not go to another school and start all over again. I've been at this school for 40 days. I wonder if I stay in Georgia and rent a truck, will I not have to do pretrip and backing since I am still within the state.
    I should ask the school if I could pay them out of pocket to take the test again since both of my free attempts are gone.
  5. alghazi
    alghazi Road Train Member
    1,173
    4,267
    Aug 29, 2014
    I know a CDL school in Utah you could go to and most likely pass with no problem--even if you had to re-do pretrip/backing.
    25(2)+2 Thanks this.
  6. dptrucker
    dptrucker Road Train Member
    4,701
    3,238
    May 14, 2012
    adelanto,ca.
    If you passed it once.. you can pass it again.
    TROOPER to TRUCKER Thanks this.
  7. Antinomian
    Antinomian Road Train Member
    2,163
    3,425
    Feb 17, 2013
    You failed the road test twice? Am I reading that wrong?
    You have to take all three parts of the test each time until you pass all three. As far as I know, Georgia DDS will let you take it as many times as you want, but you have to set up a new appointment each time. If you're going to rent a truck and go on your own you'll have to have someone drive the truck to the testing facility for you. And they will have to have a way to come and get the truck if you fail out on the road. So you'll need to take a car also. That actually happened to a student from the CDL school I went to. He hit a curb going around a corner and she told him to pull it over.
  8. Chinatown
    Chinatown Road Train Member
    77,516
    182,740
    Aug 28, 2011
    Henderson, NV & Orient
    Some food service companies hire drivers as "driver helpers" with only the cdl permit then give you 60 - 90 days to pass the cdl test at the DMV. Not all terminals do this so you may have to shop around. At least your receiving a paycheck while learning.
    You apply for "driver helper" with these companies:
    Reinhart Foodservice
    McLane Foodservice
    Sygma Network
    Gordon Foodservice
    Performance Food Group
    US Foods
    Sysco
    Southeastern Freight - I'd put this company as a first choice.
  9. Moose1958
    Moose1958 Road Train Member
    15,283
    33,921
    Dec 17, 2010
    Williesburg, Virignia
    You can not take a permit issued by one state and skills test in another. YOU MUST START THE PROCESS OVER. I'm not 100% sure but I don't even think permits are uploaded to the clearing house system anyway. This is VERY IMPORTANT. If you get a permit in one state and are stopped in another the Officer might not be able to find your permit in the system. If this happens you might find yourself in some VERY SERIOUS TROUBLE. Remember a class A CDL permit is not valid unless you also have in your possession your original DL.
  10. Moose1958
    15,283
    33,921
    Dec 17, 2010
    OK if all else fails read the OPs post not the replies because doing so can make you look like a #######. You have not provided enough information. DID YOU GO TO Ga DEPT OF DRIVERS SERVICE AND TAKE THE WRITTEN TESTS? If not you HAVE NO testing to transfer even if you could. If I am reading between the lines right you have these permits. YES you can go anywhere in Georgia and skills test until that permit expires. NO you can not go anywhere outside of Georgia and do it.
