Does the brand matter??
Discussion in 'Volvo Forum' started by jtjslim2, Dec 3, 2014.
  1. jtjslim2
    jtjslim2 Light Load Member
    52
    Nov 8, 2014
    Im rebuilding my cummins isx 450 st2 on my 2003 volvo 780. The rebuild kit from volvo is around 4k. They got sum at 2500 on ebay. Does the brand matter??
  3. Six9GS
    Six9GS Road Train Member
    1,473
    3,697
    Dec 3, 2012
    Yuma, AZ
    I do not have experience with diesel. But, with auto parts most replacement part manufacturers make adequate replacement parts. However, going with OEM parts usually lends a greater certainty that the parts are good. There are a few off-brand manufacturers that make crappy parts. I'd say you have a bit more to consider than just the cost of the replacement parts. The downtime and labor for such a rebuild is a significant cost of the project and in my opinion, considering you probably want to be able to rely and depend on the rebuild, I'd go with the OEM parts, even though the cost is greater. It'd give me a much better warm fuzzy that the rebuild itself will last as long as it should and defective or inferior parts will not shorten the life of the rebuild itself. That's what I'd do if I were in your position unless I simply did not have the resources to purchase the OEM parts. Regardless, good luck to you.
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    What is the cost difference of 4,000 vs 2,500 over the next estimated 600,000 miles the rebuild should last for?
  5. jtjslim2
    52
    Nov 8, 2014
    Thought it was 1000000? And well i got 5k...but need 6 tires including two steer tires, and 1k for mis.parts....
  6. jtjslim2
    52
    Nov 8, 2014
    Its not lack of wanting oem parts, its my funds r low
  7. RunFlat
    RunFlat Light Load Member
    185
    158
    Jul 14, 2012
    I while back I was looking at a pete with a cummins in it, which needed a rebuild, and everyone I talked to said spend the money, go with cummins genuine parts, don't get the other brand.
  8. 315wheelbase
    315wheelbase Heavy Load Member
    783
    602
    Oct 26, 2014
    there are many overhaul kits for cummins and other engines made by companies other than the original engine maker,,I would always use only parts made by the original engine maker,,I am sure some aftermarket parts are good,,I would not do it. Overhaul parts are not highest cost of an overhaul,,,the labor is what cost the most,,Would you buy a truck with a cummins or cat engine that does not have cat or cummmins parts? Made in India or China?
  9. G/MAN
    G/MAN Road Train Member
    7,031
    8,625
    Sep 3, 2010
    I am not sure the brand name makes that much difference. Are you planning on doing the rebuild yourself? If you know a mechanic who works on those engines regularly, you could ask and see what he says. I know a CAT mechanic who owns several CAT engines. He always uses OEM parts on them. He doesn't seem to think there is any difference in the quality.
  10. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    There's nothing wrong with a Lot of the good quality "aftermarket" Rebuild Kits...
    In fact most of them use the same suppliers as the OEM kits!! (there's only a few Piston ring Manufacturers in the world)
    Just do a bit of Due diligence,& if you're doing the Work yourself,some serious money can be saved.
    If you're paying for the labour though, the saving is not quite so great..
    Just My 2 cents worth..
  11. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Most of the rebuilt kits for cummins now days are made in China. So the best option to go with quality aftermarket made in the USA I've used them for n 14 cheaper and so far have 400k on it and still running perfect
