Dome light switch not working
Discussion in 'Volvo Forum' started by Carter8107, Feb 4, 2021.
  1. Carter8107
    Carter8107 Bobtail Member
    4
    Jun 14, 2020
    The dome light on/off switch on the panel in the sleeper stopped working. The light itself works when turned on/off with the switch in the cab. The replacement for the entire panel runs $150-400 so my question is: can just the light button be replaced or is it possible there’s a fix that doesn’t require replacement? Any help is appreciated. (Volvo 780 2018)
  3. bad-luck
    bad-luck Road Train Member
    3,431
    6,319
    Nov 16, 2013
    Baltimore, Maryland
    I would start with taking the panel out to make sure that the wire did not come off of the switch, and to make sure that the switch has power going to it.
  4. TequilaSunrise
    TequilaSunrise Medium Load Member
    617
    615
    Feb 3, 2016
    Seattle, WA
    Is it the fuse?? We have fuses pop when we have too much juice going to the plugs especially if you grab a cheap one from a truck stop.
    Carter8107 Thanks this.
  5. 201
    201 Road Train Member
    12,771
    26,275
    Apr 16, 2014
    high plains colorado
    A 2018 Volvo? I rest my case,,,no wait, case closed. I'm surprised they don't recommend a new sleeper, crooks. I'd say, that new a truck, fix the dang thing or it's coming through your showroom window.
    Carter8107, okiedokie and TheLoadOut Thank this.
  6. Milr72
    Milr72 Medium Load Member
    578
    1,419
    Dec 16, 2011
    S W Missouri
    Too bad X1 isn't around any longer to tell us how he'd fix it with a paper clip and foil from a chewing gum wrapper! I miss that guy!
    baha, Carter8107 and Snailexpress Thank this.
  7. Carter8107
    4
    Jun 14, 2020
    This was what I was thinking, I just wanted verification that pulling the panel to check the connection wouldn’t be a mistake, make something worse, or break something new.
    bad-luck Thanks this.
