Door problems
Discussion in 'Questions From New Drivers' started by Dumb, Apr 28, 2019.
  1. Dumb
    Dumb Bobtail Member
    Wind caught my door just right to where it wont shut now. Am i legal to bungie it closed and head to the next state to get fixed tomorrow? Or do i just shut it down until someone can fix the hinges?
  3. Dumdriver
    Dumdriver Road Train Member
    1,525
    2,138
    Jul 8, 2014
    East Coast
    Usually those doors are designed to jump off their hinges (or however you’d describe it) during a wind gust. You can usually pull it closed till you get to the shop. It’s tough, but you can close it.
    I’ve had it happen and the fleet department fixed it pretty quick and easily. But in the meantime, get it closed enough to click and you’re good to roll till you can get it fixed
    Tb0n3 Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,142
    Mar 5, 2016
    White County, Arkansas
    If the hinges or bolts in them are busted or bent or both call your dispatcher let them know. It's important those doors are stable. Both to protect the cargo and also to be in good working order. You generally do not need to leave a state to have someone come to you to replace them.
    After this episode is over, keep a box of spare bolts so you can replace them yourself.
  5. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I took it he was talking about the drivers door, am I wrong?
    Dumdriver Thanks this.
  6. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Take a wooden block and stick it between the door and the truck where the hinge is at.
    Then carefully push on the door toward the truck applying even pressure.
    The door will then bend back where it belongs and latch properly.
    Just work it a little at a time till you get it.
  7. Dumdriver
    1,525
    2,138
    Jul 8, 2014
    East Coast
    Nah, you’re not wrong. That’s exactly what i thought as well
  8. BCV
    BCV Light Load Member
    233
    436
    May 26, 2018
    I’m confused now. Post deleted
  9. Dumdriver
    1,525
    2,138
    Jul 8, 2014
    East Coast
    What’s confusing you?
  10. BCV
    233
    436
    May 26, 2018
    Thought he was talking about a trailer door. That’s what my reply was targeting
  11. MACK E-6
    49,901
    236,872
    Sounds like he meant his drivers’ door.
