The door locks on this truck will not go down at all on both doors. Any ideas on what the problem might be? When I try to lock the doors they will not give at all.
Any help would be great.
Doors won't Locks on 98 Classic
Discussion in 'Freightliner Forum' started by magellan, Apr 7, 2017.
Can you move the door locks from on top of door? You will have to remove the door panel and find the parts that are frozen and lube or replace them
Usually the door lock mechanisms start sticking after years of dirt and grime get caked up inside.
Like baha said, dissassemble and lubing should solve the problem. -
OK thanks for the help guys. I'll give it a try.
No, they will not go down using the lock or pushing from the top of the door.
Spray lots of WD>40 on the top lock button an wait for it to run down to lock catch where the door shuts on rear part of door frame, pulling the door panel is just a few torx screws and then you can pull and spray till it starts moving again?
I prefer teflon spray for locks,it doesn't collect dirt as bad.
Should be able to take the side and bottom screws out to make enough room to spray mechanism also a shot or two in the key slot. -
They have non-oil key lube. I bought some at Car Quest.
