DOT physical question
Discussion in 'Experienced Truckers' Advice' started by Commuter69, Jun 20, 2020.
  1. Commuter69
    Commuter69 Road Train Member
    1,142
    635
    Jul 2, 2014
    I was recently diagnosed with diabetes (due to family history, I have been expecting that for more than 30 years) and high blood pressure. :(
    That said, I am under the care of a primary physician to manage the issues. Unfortunately, due to how my health plan is set up, he is not authorized to sign off on the official documents for the DOT exam.... I have to be referred to "occupational health" for that. No biggie.
    I found the document online that can be filled out electronically (I didn't get into this because I have great penmanship, so I prefer to type things out as much as possible).
    On the document, there is a field to list medications I have been prescribed, that is pretty self explanatory. There is also a field where you describe any issues. In this field, I put in a statement that reads that I am under a doctor's care to manage these issues, and list his name and contact info. Is it okay to have him sign off on that statement?
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Not sure about your question but as far as the diabetes is concerned it is 100% curable, look into the Keto diet it absolutely works to get rid of diabetes.If you go here https://letstruck.com/ thy have a ton of information on it. Good Luck
    scott180 Thanks this.
  4. Lennythedriver
    Lennythedriver Road Train Member
    2,408
    8,198
    Feb 14, 2020
    Type 2? You can rid yourself of that in a few months with a little dedication and work. BP? Will go hand-in-hand with the changes you made to get your diabetes under control. Go in and take a re-exam and you’d be good to go. You got a put the cake down and exercise and get serious. I’ve seen countless people do it.
    if you go the medication route, You’ll probably be dead in five years or less, but yeah they can control it. However, you’ll have trouble getting a CDL while being diagnosed diabetic. High blood pressure they give you a year at a time as long as you’re on meds.
    nredfor88 and Chinatown Thank this.
  5. Chinatown
    Chinatown Road Train Member
    77,590
    183,425
    Aug 28, 2011
    Henderson, NV & Orient
    Many companies won't hire you with diabetes even if you have it under control on medication.
    It's perfectly legal for a company to do this.
    Work hard on diet and exercise so your blood sugar is normal. This way, you don't have diabetes, so won't have to list it.
    You'll only get a 12 month DOT medical card with Type 2 diabetes, but with no diabetes you get a 2 year card.
    nredfor88 and BigDog Trucker Thank this.
  6. PE_T
    PE_T Road Train Member
    There is no cure for diabetes. There are various treatments for it, and it’s even possible for it to go into remission, but certainly no cure for it unfortunately.
  7. Lennythedriver
    2,408
    8,198
    Feb 14, 2020
    Yes there is! It depends on whether you have type one or type two. 90% of Americans who have diabetes have type two. Which is simply caused by a really crappy, nonexistent exercising and crappy diet. Within 30 to 60 days of changing those things the diabetes goes away.
    veey “curable”
    now type 1, That’s caused by the insulin deficiency, and that’s a different story.
  8. PE_T
    Post the link from a reputable source. I couldn’t find one.
    It appears you are talking about diabetes going into remission, which is not a cure. Diseases that go into remission can return. That’s not the same thing as a cure.
  9. LDLWells
    LDLWells Heavy Load Member
    782
    1,219
    Jan 14, 2019
    Why go to the ER for a broken leg? There's no cure for it.
    I can only imagine your thoughts on real medicine
    JAYROK and 401-Alex Thank this.
  10. snowwy
    snowwy Road Train Member
    20,609
    13,323
    Jul 6, 2009
    www.google.com
    Can diabetes be cured?
    Even though there's no diabetes cure, diabetes can be treated and controlled, and some people may go into remission. To manage diabetes effectively, you need to do the following: Manage your blood sugar levels.
    Can diabetes be cured permanently?
    Although there's no cure for type 2 diabetes, studies show it's possible for some people to reverse it. Through diet changes and weight loss, you may be able to reach and hold normal blood sugar levels without medication. This doesn't mean you're completely cured. Type 2 diabetes is an ongoing disease.
    And that's THAT.
  11. LDLWells
    782
    1,219
    Jan 14, 2019
    Yeah I guess there is that. Fighting to stay obese is a weird one
    sirhwy Thanks this.
