Double over 13
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DDlighttruck, Mar 29, 2017.
  1. DDlighttruck
    DDlighttruck Road Train Member
    1,386
    19,919
    Dec 12, 2015
    What is the primary reason for a 13 double over? Do you drive it differently? Are the gear shift ratios different, or just the last one?
    I understand that a 13 d/o and tall rubber gives you long legs. A lot of "coast" trucks (running coast to coast) were spec'd that way. Just looking for some more info please.
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    They are good if you must go back empty every trip, they have been the reason for many 15 or more over speeding tic.
    Bean Jr. and DDlighttruck Thank this.
  4. AModelCat
    163,885
    This might not be the correct answer but I believe the double over 13 and 18 have an overdrive main box, which means the top hole will be overdrive regardless of splitter position.
    Oxbow, noluck, Bean Jr. and 1 other person Thank this.
  5. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    the truck in my Avatar had a 13 double over and for me it was a waste. I didn't use top gear unless I was running over 65.
    DDlighttruck Thanks this.
  6. DDlighttruck
    1,386
    19,919
    Dec 12, 2015
    So the primary reason is less fuel consumption?
    I thought it was to go fast. That's why I'm asking
  7. DDlighttruck
    1,386
    19,919
    Dec 12, 2015
    Why? Running over 65 you were lugging it too low?
    gunner76 Thanks this.
  8. gunner76
    500
    137
    Mar 11, 2010
    IA
    It's allows you to go fast and use less fuel. I think at slower speeds the Double over might actually hurt you because the engine is running too low.
    BoxCarKidd and DDlighttruck Thank this.
  9. gunner76
    500
    137
    Mar 11, 2010
    IA
    It ran too low RPMs at 55-60 for my liking when loaded.
  10. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    My '96 T600 had a double over and 3.90 rears. It was a great setup. 470 Detroit in it. Easy out of the hole when heavy and great cruising.
  11. DDlighttruck
    1,386
    19,919
    Dec 12, 2015
    This might devolve into a fuel saving thread. So, if I understand it right, you need to learn the motors optimum fuel performance RPM. Say 1400 rpm for arguments sake. Then you try to drive at that rpm.
    So if you wanna drive 85mph a 13 d/o may keep you close to 1400.
