Downhill With A Dead Engine
Discussion in 'Trucking Accidents' started by mjd4277, Sep 25, 2024.
  1. Truckers Report Jobs
  2. Flat Earth Trucker
    4,313
    16,538
    Nov 19, 2018
    With so many truckers out there struggling to maintain control of a truck with a working engine, one can truly appreciate this headline.
    Without ever being in this situation, I would like to think that I could bring the tractor to a halt immediately following or during an engine shutdown situation by fully depressing the service brakes or setting the tractor and trailer brakes before gaining too much speed.
    Otherwise, I would hit the ditch before gaining much speed.
    Vampire, Tb0n3, LoneRanger and 4 others Thank this.
  3. hope not dumb twucker
    6,076
    52,905
    Aug 23, 2022
  4. buzzarddriver
    3,823
    11,528
    Feb 1, 2011
    Dallas, TX
    Hopefully he had a manual transmission because even a dead engine in gear will keep running the compressor.
  5. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    All in all... I'd sayvhe did a pretty good job with what he was given. And at least when he did lay it over it was to the uphill side. Could have been alot worse had it layed over to the downhill side.
  6. JC1971
    JC1971 Road Train Member
    2,681
    9,807
    Jul 29, 2013
    Southwestern U.S.
    I was told if an automatic rolls in neutral with the engine off it severely damaged the transmission. I find that hard to believe that if the engine quits while you're driving, it immediately ruins the transmission. It seems like a poor design.
  7. Arctic_fox
    4,506
    25,406
    Sep 16, 2016
    Big oof, that there is nightmare fuel. And while we dont know the full story, one gots to wonder why as soon as he lost power he didnt instantly lock it up and bring her to a stop. Or othetwise at least slow it to a point he could hit a ditch semi safely with minimal damage.....or just how fast he was going/how heavy he was thay he lost his brakes trying when the engine failed? Afterall unless your brakes are already hot, They will as a rule bring a truck to a stop or heavily slow it even on the steepest inclines once....at least if your going the posted speeds. Course if his brakes were already near overheat when the engine went, or he was going too fast for his load that indicates a totally diffrent issue....
    Regardless given what we saw and could see he did about as good as could be expected in that situation. Only question on competince is what LEAD UP to that situation. The handleing OF he did about as good as could be expected. Hope he is alright.
  8. Cattleman84
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    The way it was explained to me was that there are some big beaeings in the transmission that are fed oil from an oil pump on the engine. If the transmission is turning but the engine is not, the pump doesnt provide the needed oil and it very quickly cooks those bearings.
  9. Hammer166
    7,601
    27,764
    Aug 18, 2007
    ~8600+' and loving it!
    That is true in automotive transmissions, although the oil pump is not on the engine, it's on the front of the transmission and requires the engine turning for the pump to turn. I don't know enough about Allison's to say if they are that way, but any of the automated manuals in big trucks, it's not an issue, as they're splash lubed.
  10. jamespmack
    216,477
    I-shift, I-Mac. Junk if you move them.
    JC1971, Oxbow and Flat Earth Trucker Thank this.
