Downshifting help
Discussion in 'Ask An Owner Operator' started by Andrewcalf999, Sep 4, 2021.
  1. Andrewcalf999
    Andrewcalf999 Bobtail Member
    15
    6
    Sep 4, 2021
    Hey I need help downshifting 13 speed without clutch, what rpm & speed. My instructor taught me rev the engine neutral rev again then downshift in gear
  3. BigBob410
    BigBob410 Road Train Member
    5,665
    74,101
    Feb 2, 2016
    Beirut on the Bay, MD.
    There are videos all over YouTube on how to do it but until you do it they’re all worthless in my opinion.
  4. DUNE-T
    DUNE-T Road Train Member
    7,031
    17,104
    May 10, 2015
    Detroit, MI
    While upshifting, learn what gear corresponds with what speed, so when you will be downshifting, just glance at the speedometer and put it in the gear that's needed
    gentleroger and staceydude Thank this.
  5. Andrewcalf999
    15
    6
    Sep 4, 2021
    What rpms and speed should I downshift without clutch ?
  6. xsetra
    xsetra Road Train Member
    5,189
    7,137
    Aug 21, 2011
    opposite when you upshift
    Bean Jr. and okiedokie Thank this.
  7. skallagrime
    skallagrime Road Train Member
    3,854
    9,926
    Apr 10, 2012
    Indiana
    On the average for split side (5 -12 or 6-13, or 5l to 8h, whichever you want to call it) roughly 200-250 rpm up or down
    On the low side, on the average 350-500 rpm
    Tug Toy Thanks this.
  8. Brandt
    Brandt Road Train Member
    4,616
    6,343
    Sep 17, 2012
    I would say 1,200 and 1,600 RPMs. Because it's usually 400 RPMs between full gears, not using the splitter. When slowing down and the RPMs hit 1,200 RPMs you go to neutral then raise the RPMs to 1,600 and it should go into gear.
  9. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    nobody gonna be able to tell you how to do it. Sure you can be told the concept. Its something you will pick up while you are alone and all by yourself while out on the road
  10. Magoo1968
    Magoo1968 Road Train Member
    2,055
    5,475
    Mar 18, 2021
    St Malo mb
    Silly question but if you can downshift with a clutch then shift at same rpm without one.PS rookies should get familiar with shifting before starting to float gears. The clutch is a shock absorber that helps prevents damage to driveline.
  11. Cattleman84
    Cattleman84 Road Train Member
    10,002
    71,354
    Nov 1, 2017
    The Sticks, Idaho
    What rpm depends on engine and transmission... Older trucks will require higher rpms than these newer ones.
    Best thing is to watch a u-tube video or spend some time with someone to help you. It's not something that is easy to explain with just words... You have to see, feel, and hear it.
    gentleroger and BigBob410 Thank this.
