Drag link castle nut torque
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lenny8000, Jul 28, 2022.
  1. Lenny8000
    Lenny8000 Bobtail Member
    26
    48
    Jul 25, 2022
    East Central WI
    Hello all, new to the forum. I hope this is the right section to be posting this question?
    I bought an '85 Ford LN8000 this spring and one of the ball joints on the drag link is slightly loose. I have the new link ready to install. I haven't been able to find a service manual or anything yet and I'm wondering if anyone here would know what the torque spec is for the castle nuts? Thanks!
  3. xsetra
    xsetra Road Train Member
    5,124
    7,005
    Aug 21, 2011
    Search your title for this thread on the internet. Your answer will appear. Good luck
  4. Goodysnap
    Goodysnap Road Train Member
    3,723
    9,047
    Jul 12, 2017
    120-160ft lbs for 7/8” rod end stud. Always advance or tighten to the next open slot if the cotter pin hole is blocked after torquing.
    Rideandrepair, Heavyd, xsetra and 4 others Thank this.
  5. Lenny8000
    26
    48
    Jul 25, 2022
    East Central WI
    I tried looking for the spec before and found a lot of numbers for pickups and such. Not much for bigger vehicles. Those numbers you gave seem more reasonable for the size and the studs are 7/8".
    Thank you for the help! I'm sure I'll have more questions as I go along with this truck.
    Rideandrepair and Goodysnap Thank this.
