Well i just got the low down from the Machanic.After tearing the front end all apart,my king pins are shot.....After further investigation i have to have the holes ''bored'' out and shimmed.Not great news today,but my tires were getting chewed up.I will be paying 1,350.00 for the entire job and 3 axle alignment..:disgust:...
My story started 10 months ago.I bought all new tires.Mount,dismount and balanced tires.I had new bearings and seals done too.At that point i thought i was a free man.Well,i was not a free man.One of two things have happened.
#1 being the shop did not do there ''homework'' on the king pins.This is hard to tell
#2 Shortly after the work was all done,my kings started to go.This is hard to say.But these NYC roads among other highways i run on,this is no surprise.
Needless to say i will have new steers,new kings,new seals,new bearings and new alignments.Not to mention he is going to make sure all springs and bushings are good.He said they look great.I got 1.4 million out of these kings.I may have screwed myself and went on the cheap 10 months ago.I feel maybe i should of had the kings replaced,even though at the time they were tight.Any thoughts on this king pin job.Thanks landstar8891
Dreaded King Pins..
Discussion in 'Trucks [ Eighteen Wheelers ]' started by landstar8891, Jan 31, 2013.
Page 1 of 4
1350.00 is a pretty good deal if they are boring the axle pin holes. Locally here in NC they get 500.00 just to come out and bore. Sleeves are extra. King pin sets are about 350-400 here, so thats already almost 900.00 not counting labor for the rest and the alignment.blade, keepitsimple and landstar8891 Thank this.
They don't go from good to bad that quick. If you'd jack the front up and check you could have done it yourself last year for the price of parts and saved your new tires.
if it's Eaton FA you can download pdf for maint., freeplay tolerances.
Don't forget to set toe when finished.landstar8891 Thanks this. -
That's what i am wondering.Did i in fact miss something here 10 months ago.I am pretty fussy when it comes to this ole tank i got.1997 freightliner classic.I just know i checked them and had machanic check them..I will let him no to set the toe.He just called and we are using ''brass'' pins,not the original...thanks
my oldman just had his done was like $1200 so your price is good
Darn cheap in Midwest more like 1500 and u had to do them at 1.4 mil u got there life outa them did mine at 750000 and jack front end up twice month greasing them check your shackle pins
lirn Thanks this. -
After the original kingpins they never seem to last as long. Whether its the quality of the part or poor mechanic doing the job we've always had bad luck after the originals go out.
It's the bushing that's brass. Original bushing is plastic. Need to be reamed for pin to fit. Then you can shim it how tight you want it. I could barely get grease to pump out of mine when I did 'em they were so tight.
Why not just go with Kaiser kingpins? No teaming necessary.
I like the no ream Kaiser kits too. The first one I did, I didn't think it'd last as long, but they do just fine. That's all I've been using for years and never had an issue.
Page 1 of 4
