Eaton 18 speed Driveline vibration
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Petegraintrain, Dec 16, 2022.
  1. Petegraintrain
    Petegraintrain Bobtail Member
    30
    4
    Sep 29, 2018
    Can a transmission cause a vibration? I got a bad rumble type vibration when the truck is pulling hard. It's the worst in 5th and 6th. Eaton 18 speed with a cm570 signature 600
    NightWind Thanks this.
  3. DUNE-T
    DUNE-T Road Train Member
    7,044
    17,158
    May 10, 2015
    Detroit, MI
    I would start with checking driveshafts
  4. Lazer
    Lazer Road Train Member
    1,848
    2,978
    Jan 22, 2017
    Used a truck years ago, that had a bad driveline vibration so bad by the end of my shift, I was nearly suffering from vertigo. Wrote it up numerous times. Guys that slip seated refused to write it up, so nothing was done. One morning city driver got in, put truck it gear, and BAM! the power divider took a dump. Got truck back from shop a couple weeks later, and miraculously that vibration unexplainably was gone. Told the asswipe dispatcher, maybe next time you’ll listen.
  5. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Most vibrations are from driveline problems or tires. I would start by checking u-joints and yolks. When yolks go bad the u-joint holes become egg-shaped.
  6. NightWind
    NightWind Road Train Member
    2,718
    19,173
    Nov 11, 2006
    Sunny South, AL
    It sounds like a problem with the rear ends. If you aren't having issues shifting and its staying in gear then I would rule out the tranny. I would check the entire drive line, every U-joint and yoke, hanger bearings etc. Having said that I would drop the oil in both axles checking for metal, if there isn't anything there then maybe drop the tranny oil.
  7. Petegraintrain
    30
    4
    Sep 29, 2018
    I do have a bit of extra slop in the front diff. If I lock in my power divider it shifts alot smoother and easier. Maybe thats where my problem is
  8. beastr123
    beastr123 Road Train Member
    2,950
    24,189
    Jan 2, 2014
    Moose Jaw SK CAN
    first check Ujoints, steady bearings , slip joints and ride height. These are the most often causes of vibration under load. The gear you are pulling in can amplify or minimize the vibration.
    lester Thanks this.
  9. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I would start with looking at your tires and seeing if it's possible that they could be making a problem.
    One time I had a vibration in my truck and I swapped around the tires and after that I had no more problems. That was only happening in a particular gear or two like you're saying.
    The other thing is that if your rear has a lot of slop in it, and what I mean by slop is up and down slop, then your bearing needs to be reshimmed before it gets destroyed.
