drop axles
Discussion in 'Kenworth Forum' started by bob888, May 23, 2013.
  1. bob888
    bob888 Light Load Member
    155
    9
    Feb 17, 2012
    idaho
    If you had a T-660 with dual drive axles ...
    can you replace the dual tires on the axles with single wide tires??? why would you do that???what would it cost?
    and could you replace the rear axle with a drop axle and if so what would it cost to do that??
  3. BigJohn14
    BigJohn14 Bobtail Member
    6
    May 15, 2013
    Alabama
    I believe your talking about super singles? They are are supposed to be more fuel efficient and energy efficient. Now, as how much it would cost, i'm not sure. Go to a place they would replace tires in your area and i'm sure they would be glad to get you a price.
  4. fisher guy
    fisher guy Road Train Member
    1,993
    1,061
    Mar 22, 2009
    Ocala Florida
    u are refering to super singles as stated above do a search on here and u find the pro's and cons to running the and there are some big cons
    as for the lift axle why would u want one unluss its a tri axle truck pulling heavy haul?
  5. Corporal_Clegg
    Corporal_Clegg Road Train Member
    1,239
    605
    Oct 9, 2010
    Raleigh,NC
    There CAN be several advantages to going with one drive axle and a lift axle. If you run a lot of dead head miles, or if you run a good percentage of light freight. By going to one drive axle you can run cheaper and lower rolling resistence trailer tires on the dead axle which saves fuel and tire cost. The lift axle will also give some fuel savings but its not a huge difference.
