DT 466E Question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kgktm, Sep 12, 2011.
  1. kgktm
    kgktm Bobtail Member
    49
    Jan 26, 2011
    07825
    Have a DT 466E w/137k on it.Getting coolant in oil.#3 liner leaking.Pulled head #3 piston scoared bad.Pulled liner o rings broken,no broken rings on piston.All other liners are good and cross hatch still visible.Did the leaking sleeve cause cylinder to get hot causing piston damage.Or vise versa.I wouldn't think a piston scuffing cylinder wall cause 0 ring damage.The cylinder would have to move and there is no visible sign of movement.
  3. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    I serviced a large fleet using this engine. We had a steady diet of random liner packing failures for a long time. The O-rings are at fault here. When they fail, the coolant leakage allows air around the liner overheating the cylinder sometimes scoring the piston.
    At minimum, all liner packings should be renewed on all liners or others will randomly fail down the road.
    We made it standard procedure to buy an overhaul kit and refresh the engine at the time of first liner packing failure. There were no more failures of liner packings after overhaul.
    kgktm and Heavyd Thank this.
  4. kgktm
    49
    Jan 26, 2011
    07825
    Thanks ordered the rebuild kit going to refresh the motor.
  5. bender
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    I think that's the best choice, unless of course someone is on a tight budget. The overhaul kits for these engines is very reasonable and the labor will already be there replacing all the liner packings.
  6. Heavyd
    Heavyd Road Train Member
    7,826
    6,275
    Feb 4, 2009
    I was going to say too the orings are just junk. Most of the engine's oring seals reacted bad to the orange coolant and shrunk after a few years, so they would leak. Leaking front covers was the usual dead giveaway. The overhaul kits are good. The seals are fully compatible with orange, (long life) coolant. These motors are pretty cheap to overhaul.
    kgktm what year is your truck? Does it use orange or green coolant?
