Dual steering box issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Peterbilt37904, Oct 29, 2022.
  1. Peterbilt37904
    Peterbilt37904 Bobtail Member
    I have a 2005 Kenworth W900 with dual Sheppard Steering Gears. I recently had both boxes replaced, all new lines, new filter, new fluid, new pitman arms and drag links installed. Problem now is, it will turn left no problem but when trying to turn right it is almost impossible. This is with truck jacked up. When on the ground, it will not turn at all. If we reverse the lines off the master box, it will turn right just fine but not left. The only thing not replaced is the power steering pump. This will be done tomorrow. Any other ideas? Thank for any input.
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If you can get a pressure gage to see what pressure the lines leading to each box are getting when you turn the steering wheel?
  4. Inderjit
    Inderjit Heavy Load Member
    767
    732
    Sep 17, 2017
    Why were the original steering gears replaced?
    Are there three hydraulic connections on the slave gear?
  5. dillydog24
    dillydog24 Light Load Member
    66
    53
    Jun 8, 2020
    Do you happen to know how those hoses are routed? I’m working on an adding a slave box to my one. I don’t know if I need to change out my master or not. My master is a m100
  6. HP510
    HP510 Bobtail Member
    25
    8
    Sep 4, 2019
    I have issues with stiff steering from factory,2022 with 90k miles on the truck. Drove other trucks and feel way easier to turn than mine. I have dual Sheppard but not sure how to fix the stiff steering, after i replaced my tie rod 10k miles ago it felt little better. How do I fix this heavy steering issue?
