Dumb question about flatbed.
Discussion in 'Flatbed Trucking Forum' started by Torin, Sep 29, 2019.
  1. Torin
    Torin Bobtail Member
    32
    30
    Jul 18, 2019
    Can I load my bicycle on my trailer like it was any other load and not get harassed by DOT?
    Coffey Thanks this.
  3. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    I used to. If you really want to be legal you’ll need a tie down that can be tightened, like a ratchet strap, that has a visible WLL.
    or you can find somewhere where else using a bike rack on a headache rack. On full truckloads I would have to rig a ratchet strap through the cross members and suspend the bike under the deck.
    The thing about strapping it down, i bent my rim and ended up messing my chain alignment up because of the way I used to lay it on its side and tie down.
    Lepton1 and tscottme Thank this.
  4. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Yes, it just has to be secure, like any other freight.
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,142
    Mar 5, 2016
    White County, Arkansas
    Sure you bet, toss it on there. Ratchet strap that thing. Don't bend it.
    If it is a premium bike keep a eye on it baby sit that thing. Or better yet tarp it. (HA... head scratcher. Whatcha you got under there?)
    austinmike Thanks this.
  6. Qbf594
    Qbf594 Road Train Member
    1,642
    8,715
    Aug 15, 2019
    Southern Canadian annex, NY
    I strap (3) 4x6 timbers across my catwalk butted up to the quarter fenders. when I need em on the deck I use them, otherwise I have a really nice area to stand on while working. they fit under the deck swing fine and got me to thinking of ways to utilize the catwalk space. you can't park the bike across it due to trailer swing, but you could probably park front-back with the back wheel in a cradle in the center and hang the front wheel up off the headache rack....? I can't see any headache rack with space for a bike unless you can lift way over your head....
    I'm also considering a bike for next spring so put up pictures when you figure out how you're going to rig it...
  7. Zeviander
    Zeviander Road Train Member
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    No such thing as a dumb question. Only dumb answers, lol.
    Anything that's on the truck, catwalk or trailer has to be secured with something either designed to secure something (i.e. a bolt or similar fastener for something more permanently attached) or a temporary securement device rated with a WLL (or it will be assigned a minimum WLL as laid out in the green book).
    Certain states and provinces (Minnesota and Ontario specifically) are getting pretty picky over what counts for securement. Bungees or tarp straps are out for the most part now, for anything besides a tarp.
    So dunnage has to be in a rack or on the deck (not across the legs anymore), secured with a strap (no bungees) and anything else on a part of the truck needs to have a strap across it holding it in place.
    So long as you aren't crossing the border, DOT won't hassle you about the bike so long as it's strapped. If you are planning on crossing the border, strap it to the headache rack since if it's on or in the trailer, and isn't a "tool" (a bike would be hard to get passed an a-hole CBP/CBSA agent) it has to be listed on a manifest and be detailed on a customs form sent in on the trip.
    blairandgretchen, x1Heavy and Torin Thank this.
  8. Torin
    32
    30
    Jul 18, 2019
    I'm actually heading to Canada now so that is really helpful. I have wooden v-boards on my catwalk right now, does that need to get put up before I cross?
    x1Heavy Thanks this.
  9. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    It should not be a problem as long as they are secure, by secure I mean strapped, not bungied or strapped with a 1" strap. Canada pretty much goes by the same laws we do on securement.
    I used to run Canada all the time and never had any grief from having any personal items on the trailer, but I guess a guy could run across one that didn't like it.
  10. JonJon78
    JonJon78 Road Train Member
    7,232
    42,861
    Jul 1, 2018
    Can you post the regulation stating this?
  11. INRUT
    INRUT Medium Load Member
    555
    2,023
    Aug 21, 2016
    Absolutely, I’ve seen several drivers put tires between 4/4’s built up on catwalk or deck.
