Dump Truck Bouncing
Discussion in 'Ask An Owner Operator' started by josephbolda, Jul 2, 2020.
  1. josephbolda
    josephbolda Bobtail Member
    5
    97 International tri axle dump truck bounces consistently. Thought maybe it was tires so replaced all 10 tires and the bounce got WORSE! It is not the death wobble. Kingpins good, tire rods good, leak springs good, whole front end checked and all good. There is a little play in one of the U joints. Had wife take a video driving behind me and it doesn't look like it is coming from the rear end. It bounces from all gears and speeds. Tried putting it in neutral and it still was hopping. Taking it back to the tire place in 4 days. They are closed for the 4th of july weekend of course. Anyone have suggestions on what I can do to try to figure this bounce out before I can bring it back to the tire place?
  3. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    What kind of suspension in truck?
    AModelCat Thanks this.
  4. bad-luck
    bad-luck Road Train Member
    3,407
    6,274
    Nov 16, 2013
    Baltimore, Maryland
    Can you post the video? Check cab mounts. Do you feel anything in the stick? Do you have bud wheels? How about the shocks, are they new?
  5. Long FLD
    Long FLD Road Train Member
    12,733
    53,177
    Mar 4, 2015
    Put the backend on jack stands and check the runout on your tires.
    If you have hub pilot wheels you could buy the Trubalance sleeves and get everything centered on the hubs.
    jamespmack Thanks this.
  6. jamespmack
    216,381
    Agreed, how .uch you wanna bet he bought Chinese tires too.
  7. josephbolda
    5
    Hendrickson walking beam suspension, front drive tires are cosmo and the back 8 are transporters from turkey. The shocks are all original 97 international. Don’t think it’s the shocks though.
  8. josephbolda
    5
    What boggles me is putting all new tires on it made it 10X worse! The front was all check at the mechanic and was good. There is a semi loose U bolt that has a little play in it when I pull the driveshaft up and down. We tightened the cab mounts down more and didn’t help. I just don’t want to keep throwing money at this old b**** if I can pinpoint the problem!
  9. bad-luck
    3,407
    6,274
    Nov 16, 2013
    Baltimore, Maryland
    Wait a minute.... The shocks are original 1997! 23 year old shocks, and you have a bounce! REPLACE the shocks!!!!
    Ruthless Thanks this.
