Dump truck
Discussion in 'Ask An Owner Operator' started by Yankee12, Jul 11, 2018.
  1. Yankee12
    Yankee12 Bobtail Member
    Texas
    I've had some pneumatic trucks on the road for a while now. I'm looking to expand a bit. I'm toying with the notion of getting some dump trucks on the road locally. As there is a lot of construction where I'm located at now. Is it worth it? What steps should be (and could be) taken to get a construction company to lease done trucks from me? Any other advice would be appreciated. Thanks in advance.
  3. Trailerdragger
    Trailerdragger Light Load Member
    94
    83
    Mar 26, 2017
    A lot of those "construction companies" don't pay, that's why they're always looking for people to haul their dirt.
  4. Yankee12
    Texas
    Any other suggestions for a dump truck then? Or would you say that it's a dead end all together?
  5. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    It depends what area of the country that you are in. Some areas do much better with dump trucks than others.
    And then there's the issue of actually finding a truck that's in good enough shape to use. They take a tremendous beating because all of the weight is on the truck itself.
    And finding good drivers is easier said than done.
    But in the right part of the country you can do well with dump trucks.
  6. 201
    201 Road Train Member
    12,763
    26,260
    Apr 16, 2014
    high plains colorado
    About 1/3 of my trucking was dump truck ( tri-axle and trailer), it's a cut throat business, or at least it was. Not sure about Texas, but in the Badger, most of the work was by bid, and how odd the same guys got the contract year after year. Repairs will kill ya, because, half the time, you are hauling max ( or more) weight over the toughest terrain, and the only truck that can handle that, I've found, is a Mack.There's better trucking to go into, flatbed seems wide open, and pneumatic tanker is pretty specialized. Unless you know someone in the gravel/paving biz, you'll get the craX loads no one else wants.
    LoneCowboy and okiedokie Thank this.
  7. Yankee12
    Texas
    Thanks for the replies fellas. Stay safe out there.
  8. tericorlepvk
    tericorlepvk Bobtail Member
    7
    What is a good price for used dump truck?
