e-fuller 10 speed grind
Discussion in 'Volvo Forum' started by Rudy5, Aug 5, 2013.
  1. Rudy5
    Rudy5 Light Load Member
    54
    Mar 17, 2013
    Have a ten speed Eaton fuller which grinds when I split from 5th to 6th gear. The other gears are very smooth, no grinding. Anybody got any suggestions on what might cause this?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    R u flipn be.4 u shift if yes back box must be rebuilt
  4. Rudy5
    54
    Mar 17, 2013
    Yeah, I flip b4...is this black box rebuild costly?
  5. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    no could be round air filter at rear back box. clog can slow change enough 2grind real trans shop not dealer best bet
  6. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    Man, I would certainly check the splitter box or "Back Box" It sound like it may not operating correctly! I wish you luck.
  7. Rudy5
    54
    Mar 17, 2013
    Thanx, and that's the first thing I'm going to check on. I only hope that it's only that and nothing more stood and/or expensive.
  8. VolvoTech0816
    VolvoTech0816 Bobtail Member
    39
    8
    Aug 4, 2013
    I dont know what year make and model you have but you might want to look into the XY shifter that is located on the top of the tranny, we replace these frequently at the dealer. hope this helps
  9. Rudy5
    54
    Mar 17, 2013
    Okay, I'll have it checked out also. Is the replacement costly? Thanx for the information reply.
  10. VolvoTech0816
    39
    8
    Aug 4, 2013
    the XY is spendy around 600-700$
  11. Rudy5
    54
    Mar 17, 2013
    Yikes! Okay, then, I'll begin the checks with the least costly to the more expensive ones. Once again, thanx.
