Eaton 13sp difference
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Guardian, Jan 29, 2012.
  1. Guardian
    Guardian Bobtail Member
    28
    5
    Jan 27, 2012
    I have a eaton 13sp, 1650 tq can some one tell me the exact difference between the 1650 and 1850 tq ? Can 1650 be upgraded? Or more cost effective to swap trannys? Already have a 2100 ft. lb. clutch. Any thoughts?
  3. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    They are the same. Bearings are the same, gears are the same. Ask any independent honest transmission guy.
    Oxbow and Guardian Thank this.
  4. dirthaller
    dirthaller Road Train Member
    1,124
    13,264
    Sep 22, 2011
    Coloratah
    I have an 03 with a RTLO16913A in it and I asked my gear guy why someone wouldn't speck a RTLO18913A with the big engine. He said whoever ordered it was trying to get away from the liquid cooled tranny cooler. He says they are the same.
    Oxbow Thanks this.
  5. Guardian
    28
    5
    Jan 27, 2012
    Someone else told me difference was external cooler, hell I don't know lol
    Oxbow Thanks this.
  6. ProduceHauler
    ProduceHauler Light Load Member
    231
    24
    Apr 28, 2011
    California
    I have heard some (just few) gears are made of higher grade steel - that supposed to be only difference between 2050 and 1850 torque versions
    W903B Thanks this.
  7. Les2
    5,150
    2,288
    Jul 25, 2008
    IIRC the bearings/shafts are bigger in the 2050 and bigger trans.
  8. ENR
    ENR Light Load Member
    254
    50
    Oct 8, 2009
    Ontario
    Can you provide a link for that ?
    I've been looking myself to find the difference between an RTLO18918B and RTLO20918B and the specs from eaton state that they are EXACTLY the same in size and weight. I haven't been able to determine one verifiable difference.
    The guy's at the shop I was buying my tranny mentioned something similar to you, but with the shrug of the shoulders... they were guessing.
    thx
    Edit, I just googled IIRC and see that it means " if I remember correctly " sorry.
    Where's my daughter when I need her.
  9. Les2
    5,150
    2,288
    Jul 25, 2008
    I only know there is no difference between the 1650 and 1850. What the difference with the higher ones I'm not sure, but I was told there is one.
    I'm going off of what my transmission guy told me. Like he said, if there was a difference, the bearings and gears wouldn't have the same part numbers....
    And no you will not find a link from eaton or any transmission builder about it, that would be admitting they was lying and could probably end up in a lawsuit over it.
    Its a scam with them and truck makers. If you want to turn up a 475hp 1650 torque to 550hp 1850 torque they want you to pay for the extra warranty on the trans which is a only a 1650 ft lbs trans. You actually pay for nothing.
  10. Guardian
    28
    5
    Jan 27, 2012
    Lol it's amazing st the bull #### we endure in this industry
  11. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    I would look for the difference being in the case where it wouldn't be easily detectable, such as higher nickle content in the casting and/or additional material for support. The internals could be identical in a stronger housing to up the rating.
