Eaton 8LL
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by City-Boy, Apr 29, 2025.
  1. City-Boy
    City-Boy Light Load Member
    101
    110
    May 20, 2017
    Deep south BAMA
    I've owned this truck roughly 3 years now its been overhauled and new clutch last March alls been great!! Altho I'm still having to bury the clutch pedal to the floor to get in gear!! So I get loaded today in Columbus Ohio rolling down 71 in top gear and all of sudden my truck starts reving like I'm out of gear but I'm not! Pop it out throw it back in and it's fine. Well then it's happening left and right in 8th and 7th gear! I've noticed when it happens if I let the rpms come back down or rec it it seems to catch and continue on rolling! All while still in gear. My trans temp seems fine and not a single issue until now any thoughts?
  3. Big Road Skateboard
    7,091
    40,179
    May 2, 2021
    Clutch slipping.
    I'm betting no free travel either. It's so far out of adjustment you have no clutch brake and no free travel.
    Basically it's pushing the clutch down without your foot
    W923, Rideandrepair and City-Boy Thank this.
  4. City-Boy
    101
    110
    May 20, 2017
    Deep south BAMA
    Is that adjustment needed or worse?
  5. Big Road Skateboard
    7,091
    40,179
    May 2, 2021
    Sounds like it's needed an adjustment for a LONG time. I've seen it quite a few times, and got away with adjusting it.
  6. City-Boy
    101
    110
    May 20, 2017
    Deep south BAMA
    I apologize it wasn't showing your whole reply
    Big Road Skateboard Thanks this.
  7. City-Boy
    101
    110
    May 20, 2017
    Deep south BAMA
    I sincerely appreciate the replies I'll get that adjusted today unfortunately something I've been meaning to do! Shows putting things off ain't a good idea
  8. City-Boy
    101
    110
    May 20, 2017
    Deep south BAMA
    So took the truck had clutch adjusted still slipping like craxy they said once it starts slipping the clutch is done!! Facts or shop talk?
  9. Big Road Skateboard
    7,091
    40,179
    May 2, 2021
    Do you have free travel and clutch brake now?
    The statement that once it slips it always slips is false, but that doesn't mean you didn't burn it up
    W923 and Rideandrepair Thank this.
  10. City-Boy
    101
    110
    May 20, 2017
    Deep south BAMA
    She goes in to gear no signs of slipping on lower end
  11. SmallPackage
    5,777
    18,547
    Dec 20, 2019
    Marion Texas
    Are you sure its the clutch? It may be “neutralizing” through the range solenoid. May be sticking or leaking air causing it to put the trans in neutral like its between ranges.
    Rideandrepair Thanks this.
