Eaton Fuller
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ei, Sep 9, 2013.
  1. Ei
    Ei Light Load Member
    79
    7
    Aug 18, 2013
    Northeast
    10spd whats the torque rating on the eaton fuller model FRO13210c? or max torque it can handle ?
  3. lester
    2,956
    8,075
    Jan 2, 2012
    NW, Iowa
  4. Ei
    79
    7
    Aug 18, 2013
    Northeast
    so if I wanted to beef up the engine for more power horsepower/torque! What will have to be done to the tranny/clutch wise to make this work with the above transmission model?
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    You would have to replace the clutch and trans to match the torque output of the engine, or be careful!
    cetanediesel Thanks this.
  6. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    drive like you have an egg between your foot and the throttle, and don't think you're going to go pulling a hill at full throttle at peak torque. That's a good way to twist off drivelines:yes2557:
    That being said I've seen my motor backed by a 15spd. Those are rated for 1400 or 1500 ft.lbs I believe. So in theory if they really are a 1400 ft.lbs.tq transmission they're pushing 500-600+ft.lbs over what they're supposed to be at the flywheel yet they still run.
    capper17 Thanks this.
  7. capper17
    capper17 Light Load Member
    136
    145
    Sep 6, 2013
    Stuart, IA
    That's a great line and visual......
    379exhd Thanks this.
  8. 379exhd
    2,925
    3,153
    Jun 25, 2012
    That's how I was taught to drive. I learned that with my pickup too. Tranny is rated at 500 she's running over 700ft.lbs. through there. I didn't feel like twisting off an input shaft or blowing the rear end out.
  9. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,488
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Most FRO transmissions are capable of more torque in the top two gears, it would be rated at 1400 in 9th and 10th.
  10. VinceL
    VinceL Light Load Member
    143
    24
    Jul 21, 2012
    Cleveland, TN
    What motor do you have and how much beefing up are we talking about?
  11. Marmon man
    Marmon man Light Load Member
    118
    32
    Mar 31, 2008
    If you don't have a Transmission Oil Cooler, you should install one before uprating your Engine. If i remember right, it's required in Eaton Fuller Transmissions rated for more then 1300ftlbs...
