ECM on 3406E
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jd2210, May 6, 2015.
  1. jd2210
    jd2210 Light Load Member
    65
    14
    Oct 23, 2009
    I have 96 3406E that apparently has a bad ECM. I also have a parts motor here that I think it from a 98 3406E. Can we install the 98 ECM on the 96? Do I need to have it programmed first? My dealer is claiming that I need a new one for $3300 and that sounds very steep to me.
  3. 1johnb
    1johnb Medium Load Member
    542
    405
    Jun 13, 2012
    New Paris Ohio
    If both ecms have the same pin count they will interchange. The earlier one should be a 40 pin. The 98 may be a 70 pin. If the pins are the same check out the specs on each engine. You may need to contact a dealer for guidance. But reflashing should not be to castly.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    should be 40 pin for both.(square looking plugs) just flash the program and go.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Post photo of ECM to identify
  6. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    by what I'm gathering you've got a 5ek and a 2ws. If my mind serves me correctly a 40 Pin and a 70 pin platform. They won't swap you won't know without looking but I could have sworn a 2ws or the rare 6ts I believe was a 70 pin ecm
  7. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    I thought 2ws was 2000. maybe late 99. I don't think 2ws#'s were around in98. never seen a 6ts with 70 pin. 98 was 1lw or 6ts 40 pin. and the rare 1mm in 99.
  8. sunsation288
    sunsation288 Light Load Member
    55
    54
    Jan 12, 2014
    I am pretty sure you have a 5ek and a 1ws , ECM wise they both have the same part number , but need to be programmed , they don't have the same low nox programation
  9. 379exhd
    2,925
    3,153
    Jun 25, 2012
    For some reason I had it in my god forsaken head that it was a 99 year model motor. My mistake. 2000 would he a 2ws in truck years correct 99 in a motor year. Idk why the hell I got so confused long day yesterday
  10. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    yer forgivin! LOL
