ECU
Discussion in 'Experienced Truckers' Advice' started by AriGab, Dec 2, 2024.
  1. AriGab
    AriGab Light Load Member
    62
    27
    Feb 3, 2023
    Hey everyone, sorry if this question has been answered before. I'm not good with forums lol. I am looking at possibly buying my first truck. I have always worked for other companies so I was wondering if when you buy a new truck if it automatically comes with a speed limiter? I am looking at a 2025 Peterbilt 567 day cab. My current company has the speed set at 63mph and in NH the speed limit is 70mph. If it comes from the factory with a speed limiter does anyone know what that speed is? Also can it be removed in the ECU if I own the truck?
  3. Lonesome
    Lonesome Mr. Sarcasm
    11,676
    24,348
    Dec 15, 2007
    Northern Indiana
    I would think, if you own said vehicle, you may set the speed at anything you wish.
  4. AriGab
    62
    27
    Feb 3, 2023
    I keep reading that there is a factory set speed limiter but it won't say what speed. It does however say 2000 - 2100 rpm's. Is anyone familiar with this truck who might know what that equates to in speed. I'm guessing gears have a lot to do with it as well. I can't find anywhere the gear options for that truck.
  5. AriGab
    62
    27
    Feb 3, 2023
    So if anyone could help me if said vehicle was a 2025 Peterbilt 567 day cab 605/2050 cummins with Eaton Fuller 18 speed automatic with 4.10 gears what would the top speed be at say 2000 rpm's? Thanks in advance
  6. Ruthless
    Ruthless Road Train Member
    9,163
    90,948
    Aug 28, 2010
    The City.
    What size tires?
    Prolly gonna be wound out pretty good at 70 on tall rubber anyway
    AriGab Thanks this.
  7. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,011
    2,077
    Dec 15, 2021
    Might be 71 but that's just a wild guess.
    2024 T880 with X 15 Cummings, 615 hp,18 speed automated,ours came set at 71 mph.Owner can get those settings changed.
    Lonesome and AriGab Thank this.
  8. AriGab
    62
    27
    Feb 3, 2023
    So I found a calculator online but I'm not sure if I filled it out correctly? So with 4.10 gears, 42" tires (11R 22.5), RPM's at 2100, transmission gear ratio at .73 it says that I would be at 87.7 mph. Does this sound right or did I screw it all up lol? I really was hoping for the 4.10's because the interstate is really up and down and our current trucks are at 31mph going up long hills. I also don't want to be at 2000 rpm's maxing the truck out at only 70 mph. So I may have to go to like 3.90 gears.
  9. AModelCat
    164,364
    4.10s ain't going to get you up the hills any faster.
  10. AriGab
    62
    27
    Feb 3, 2023
    That's weird because everything I research says higher gears for hills. I know don't believe everything you read lol. I still have to believe that a cummins 605/2050 with 4.10 gears is going to do better than 31mph up hill though. Maybe I'm crazy
  11. AriGab
    62
    27
    Feb 3, 2023
    Just for the record I am referring to a 5500 gallon septic truck. Tandem with a 20k steerable drop.
