Editing ELD
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Grouch, Aug 13, 2019.
  1. Grouch
    Grouch Road Train Member
    2,118
    4,366
    Feb 3, 2009
    Between here and eternity
    When the ELD records and shows "unidentified driving" can a company edit this in any way? Good example, a part time driver does not log into the ELD, he runs on paper, instead of running "legal", he snubs his nose at the HOS, but the ELD is still ticking and shows all his time as "unidentified driving". Can the company cover this by editing any or part of the "unidentified driving"??
  3. kemosabi49
    10,947
    47,665
    Jan 13, 2013
    SW Arkansas
    I think the owner can assign that drive time to someone. He could also fire the part time driver that caused the problem to begin with.
    x1Heavy, Cabinover101 and tucker Thank this.
  4. MartinFromBC
    2,769
    12,483
    Oct 19, 2018
    It is probably going to depend on the brand of eld more than anything. Some offer lots of flexibility, others basically none.
    Cabinover101 Thanks this.
  5. DUNE-T
    DUNE-T Road Train Member
    7,030
    17,103
    May 10, 2015
    Detroit, MI
    With Aobrd you can, but with Eld you can not
  6. CousinVinny
    CousinVinny Medium Load Member
    615
    1,772
    Jan 26, 2015
    New Jersey
    They're actually supposed to be identical in function now between any of the FMCSA-approved, registered devices on the market.
    Assuming the offending driver does not have an account in the system because he is exempt from ELD requirements, the company should mark the unidentified driving events as Won't Assign with an annotation stating the driver's name and reason for not logging in during that movement.
    If the driver is not exempt from ELD requirements and simply chooses to ignore using the device as is required by law, the company should assign any unidentified driving event generated by this driver to the driver's ELD account and then promptly instruct said driver to kick rocks and GTFO because their refusal to comply exposes the company to liability.
    x1Heavy and jammer910Z Thank this.
  7. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    In the system it has to eventually be assigned to SOMEONE.
    If you didn't do it, hit reject, and note why if there's a tab for it.
    Safety, or whomever is in charge of compliance, should know, or be able to track down the culprit.. be it the mechanics, or a rogue driver while you were on home time.
    They find them, and move those hours to the correct Log In ID.
    That's the process if done correctly.
    x1Heavy, Dieselboss and CousinVinny Thank this.
  8. ZVar
    ZVar Road Train Member
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    That's incorrect. For ELD's it's true the drive time cannot go away. In can, however, be assigned to the correct driver by the admin.
    jammer910Z Thanks this.
  9. DUNE-T
    7,030
    17,103
    May 10, 2015
    Detroit, MI
    Yes, it can be assigned to another driver, but can't be covered up. In my understanding that was what OP was asking.
    In AOBRD you can just erase or edit whatever you want to
    ZVar Thanks this.
  10. Concorde
    Concorde Road Train Member
    5,382
    18,890
    Jun 29, 2016
    West Melbourne Florida
    No worries..
    All they have to do in the event of an audit is change the drivers name with one that runs legal..
  11. Dieselboss
    Dieselboss Technology Contributor
    1,648
    1,365
    Feb 19, 2009
    DieselBoss.com
    Yes. The admin can assign, or reassign those movements to another driver or even to a generic "mechanic" account when that happens.
    Just remember that if YOU drive that truck next it will probably ask you if you want to claim those miles. Click "reject" if they are not yours and the admin will need to assign them manually to someone else.
