EEC61 CODE
Discussion in 'Freightliner Forum' started by Devo321, Aug 13, 2023.
Found these with a quick search. You should be able to do the same.
SPN 4334 FMI [2-18] Troubleshooting Explained – Camping Fun Zone Scroll down a little and there is a video on EEC 61. Don't be deterred by the 'camping'.
SPN 4334 FMI 7 EPA10 DD15 Engines | TruckersReport.com Trucking Forum | #1 CDL Truck Driver Message Board (thetruckersreport.com)
Code spn522108 failed 5 fault 1 5=12 freightliner what is fix. Freightliner Cascadia 2012 Detroit engine. Check fuses (justanswer.com) Not sure about this one as the person answered but then it lists SPN 4364.QUALITYTRUCK Thanks this. -
spn 522108 FMI 5 "Front Left fog light current below normal or open circuit"
SPN 4334 is all about DEF pressure. Do you have a specific FMI with that? For EPA10 emissions ACM fault 4334 their are three FMI listed.
FMI 2 "DEF pressure sensor - Drift", FMI 7 "DEF pressure low" (ACM is detecting DEF pressure has not built to 72 psi during a pressure build cycle {60 seconds}), and FMI 17 "DEF pressure high"RocketyMan and QUALITYTRUCK Thank this.
