EGT's
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Oscar the KW, Sep 8, 2013.
  1. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    At what sustained temperature is the maximum, before damage?
  3. Ezrider_48501
    3,845
    5,133
    Apr 2, 2011
    bismarck, nd
    some of that depends on the internals of your motor but i wouldn't want to sustain more than 1000-1100 for very long.
  4. Taildragon
    Taildragon Heavy Load Member
    723
    449
    Jun 22, 2012
    Indiana
    And I would keep in mind the accuracy of your gauge as well.
  5. VinceL
    VinceL Light Load Member
    143
    24
    Jul 21, 2012
    Cleveland, TN
    I usually keep an eye on the oil & water temps as well. I start letting her breath @ 900. Never really wanted to test that theory out lol.
  6. Oscar the KW
    12,247
    28,120
    May 19, 2011
    The hottest I can get mine to is 925, and it has to be 90+ outside to do that, I know that at that temperature it is fine, stock it ran hotter. I was just curious at what point/temperature you could start to melt things down.
  7. Ezrider_48501
    3,845
    5,133
    Apr 2, 2011
    bismarck, nd
    i believe aluminum starts to melt or soften around 1275 off the top of my head.
  8. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    Yes and keep in mind what he's going to be reading is post turbo. Not the temp at the manifold. And there are so many variables that go into post turbo EGT's its hard to say what his actual manifold temp is. I've heard anywhere from 200-400 degree difference. Is tack on 200-400 degrees to what the gauge is reading.
  9. 7.3 cowboy
    7.3 cowboy Light Load Member
    210
    59
    Mar 4, 2013
    Why are none of them in the manifold? that's what we do on all of the pickups.
  10. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Yup, just drill a small hole and screw it in. My old IDI has seen as high as 1200*. I really need to get my intercooler installed.
  11. 7.3 cowboy
    210
    59
    Mar 4, 2013
    My 7.3 has hit 1350 before water methanol
