Electret Mic without power?
Discussion in 'CB Radio Forum' started by rabbiporkchop, Feb 28, 2017.
  1. rabbiporkchop
    9,689
    6,543
    Feb 9, 2012
    Wapwallopen, Pa
    I just cracked open my AT-6666 stock mic to cannibalize parts to build a better mic without the acoustic deficiencies of the Anytone mic case, plus having the option of adding a noise cancelling electret in the future,
    and noticed pin 6 with dc voltage is unused. I also noticed no capacitor inside the mic to prevent dc voltage from feeding back into the audio chain. How does this thing work?
  3. CW Spook
    CW Spook Light Load Member
    Looks to me that the schematic is showing a dynamic mic, but that 13 volts is available on the radio connector side for power to an electret if it's equipped with a properly wired cable.
    rabbiporkchop Thanks this.
  4. Ridgeline
    22,708
    122,456
    I sort of second that, the power is also used for a mic with tone buttons (lack of a better term), the radio is a universal radio, it covers a lot of different markets and could be used in commercial applications.
  5. rabbiporkchop
    9,689
    6,543
    Feb 9, 2012
    Wapwallopen, Pa
    It is an electret soldered to the pcb.
    That's what confused me.
  6. CW Spook
    Well, if that's the case, I don't know for sure either. The wire marked RX on the schematic is actually for the up-down buttons. Maybe in TX it supplies power to the mic element.
  7. rabbiporkchop
    9,689
    6,543
    Feb 9, 2012
    Wapwallopen, Pa
    Looks like I got a new project.
    If I'm lucky it will sound almost as good as the Heil PR40.
  8. Ridgeline
    22,708
    122,456
    It's not an electret element.
  9. rabbiporkchop
    9,689
    6,543
    Feb 9, 2012
    Wapwallopen, Pa
    What isn't?
  10. Ridgeline
    22,708
    122,456
    That isn't
  11. rabbiporkchop
    9,689
    6,543
    Feb 9, 2012
    Wapwallopen, Pa
    It sure looks like some sort of transducer. If it isn't an electret then what is it?
    Blaskowitz Thanks this.
