I have a Volvo vnl 680 2013 d13 I have noticed that when I start climbing the temperature goes up rather quickly to around 210° and stays there for a bit after I get on flat again, before it used to cycle during the climb to about 180° and up again, I change the thermostat and water pump about 6 months ago and everything was working fine, but I started noticing this after (3weeks ago) change the piston cooling valve and oil temperature sensor and a oil change also my a/c is not cooling, is charge , compressor is working and it doesn't lose antifreeze, what could it be, it has an electric fan clutch and when the truck is off it has a resistance if you try to spin it, what could it be or affecting the system, can someone direct me in the right direction please, thanks.
Electric fan issues
Discussion in 'Volvo Forum' started by ElNoVaTo, Apr 24, 2022.
Your 2013 Volvo VNL 680 with a D13 engine has coolant temps spiking to 210°F during uphill climbs and staying there briefly, unlike its previous cycling around 180°F. The A/C isn’t cooling despite being charged and having a working compressor. Recent repairs include a thermostat and water pump (six months ago) and a piston cooling valve, oil temp sensor, and oil change (three weeks ago, when issues began). The electric fan clutch has normal resistance when off, and there’s no antifreeze loss.
Likely Causes:
- Electric Fan Clutch: Not engaging properly, reducing airflow to the radiator and A/C condenser, causing high coolant temps and poor A/C cooling.
- Piston Cooling Valve: Faulty or improperly installed since replacement, possibly increasing engine heat and coolant temps.
- Radiator/Condenser Blockage: Debris restricting airflow, affecting both cooling and A/C.
- A/C System Issue: Blocked expansion valve or restriction, causing poor cooling (less likely for coolant temps).
- Thermostat/Water Pump: Unlikely, but premature failure could limit coolant flow.
- Test Fan Clutch: Check if it engages (loud spin) at 200°F or with A/C on. Use a scan tool for fan codes. Replace if faulty ($300–$500).
- Inspect Piston Cooling Valve: Verify part and installation; check for oil system codes. Replace if defective.
- Clean Radiator/Condenser: Remove debris to restore airflow.
- Diagnose A/C: Check pressures (high: 150–300 psi, low: 25–40 psi). Replace expansion valve if blocked.
- Re-Check Thermostat/Pump: Test if other steps fail.
Install a fan switch to prevent it from going up towards 210 degrees
