Empty trailers.
Discussion in 'Swift' started by Box of Tj, Mar 19, 2019.
  1. Box of Tj
    Box of Tj Light Load Member
    58
    29
    Nov 22, 2014
    Common, you aren't fooling anyone. Enforcer lock and no seal? Quit hoarding empty trailers you lazy bums .I'm about to buy cheap padlocks in bulk and put them on these trailers if my DL says they're empty and available . I can play this game, too
    Mike2633 Thanks this.
  3. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    That will show them ...
  4. Opus
    132,221
    here's another idea.....call your dispatch to have it cut off. I know Schneider will do it. Just gotta suck up the time waiting on the dude to show up.
    mindes and Mike2633 Thank this.
  5. Moosetek13
    Moosetek13 Road Train Member
    14,978
    19,016
    Nov 1, 2010
    Burnsville, MN
    I carry a supply of non-Swift seals for just the right occasion. That way it looks loaded.
    And that is all you have to do if you want to tie up a bunch of empties on the lot. Seal it, no lock required.
  6. sdaniel
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Yeah , being as low as the people you are fussing about ... that’s the fix .
    Humblepie and A21CAV Thank this.
  7. dptrucker
    dptrucker Road Train Member
    4,703
    3,239
    May 14, 2012
    adelanto,ca.
    Works till you bang on side of trailer.
    Then a call is all it takes to see for sure if it's empty
  8. Moosetek13
    14,978
    19,016
    Nov 1, 2010
    Burnsville, MN
    That's true. Then it is up to them to decide if they will give it to you if it is already assigned to another driver.
    I never use that trick unless the trailer is already assigned to me.
    I have been burned in the opposite direction as well.
    I had a trailer and was dispatched on a load with it, but I was also going on home time. When I got back from home time my trailer was gone and I had to hunt down another one.
    Another time I was delivering at a store in SLC. I was told to unhook and park on the side. I was out of hours so I took my 10. When I got up in the morning my trailer was gone. Someone had jacked it during the night, and for some reason it was taken off me and given to another driver - even though I was sitting right there. The paperwork was supposed to have been left in the back for me, but it was gone as well.
    Didn't do that jerk of a driver any good however. He had gone through the terminal and they red flagged it for a cracked brake lining. I found it there when I went to find another empty.
  9. kakk86
    kakk86 Light Load Member
    104
    37
    Jul 16, 2017
    Virginia
    If you're at a terminal ask your DM to give you some available trailer numbers. Just because a trailer is empty doesn't mean someone isn't dispatched on a load and needs it.
  10. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    A Dewalt portable grinder will take off any lock.And if you want to ,"fix" them, put some well placed grind marks where the key goes in.A toothpick or some crazy glue works well also.
    Box of Tj Thanks this.
  11. Moosetek13
    14,978
    19,016
    Nov 1, 2010
    Burnsville, MN
    If the load needs an empty trailer you won't be dispatched without one.
    But as I learned, even if you are dispatched with a trailer - it may not be safe if you are not hooked to it.
