End dump tailgate air chambers
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Olivares86, May 10, 2024.
  1. Olivares86
    Olivares86 Bobtail Member
    7
    Hello everyone. I have a rookie mechanic question. Is there a different type of air chamber to operate the tailgate on an end dump?
    This is my own project, I started to rebuild an old end dump trailer I bought, so I went through all of it pretty much, from front to back replacing electrical lines, air lines, brake chambers, inboard to outboard hubs, air valves, etc. So, I come to the point where I'm replacing this type 24L air chamber that closes the hooks for my tailgate. It has two chambers, one for each hook, and when I finished replacing the driver side I realized that the hook stays in the open position while the passenger side is closed. So, I don't know if I missed something or should've done something different or maybe I should've bought a specific type of chamber for this latching system?
    Thanks for reading.
  3. abyliks
    abyliks Road Train Member
    3,923
    9,185
    May 2, 2010
    ludlow MA
    Call the dealer with the vin, or see if there’s a part number on the one you pulled off
  4. 062
    062 Road Train Member
    6,233
    33,544
    Oct 20, 2013
    Were they both closed before you started?
    Check your work.
    Make sure that you don’t have air going to the one chamber.
