Enddump
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by K9guy, Nov 19, 2018.
  1. K9guy
    K9guy Bobtail Member
    14
    4
    Nov 19, 2018
    ok I’m starting new job tomorrow first time driving a tractor trailer other than getting my class a ive driven dump trucks but never an end dump is it a bad idea
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    My neighbor makes good money doing that here locally in Phoenix, just be careful when your dumping your load, don’t want to tip over. lol
  4. K9guy
    14
    4
    Nov 19, 2018
    Yeah for sure I’m nervous which is a good thing
  5. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    What city are you in?
  6. J Rich
    J Rich Medium Load Member
    363
    380
    May 28, 2018
    Atlanta Ga
    Why would it be a bad idea? What kind of trailer? Framed or Frameless? Gate or Barn door? Level ground is your best friend, and watch out for over head obstacles when dumping.
    Nothereoften Thanks this.
  7. K9guy
    14
    4
    Nov 19, 2018
    Frameless
  8. J Rich
    363
    380
    May 28, 2018
    Atlanta Ga
    Just be careful! It's not hard to lay one over when dumping. You need the trailer as level as possible. Make them give you a level spot! You also have to think about the ground you backed over to get to that dump spot. Because, you will be pulling forward for several feet with the bed up in the 3rd-4th stage. Best of luck.
  9. blade
    blade Heavy Load Member
    881
    647
    Jan 30, 2009
    Some where, Mo
    I will add Dont let your receiver boss or rush you to unload they don’t care if you end up on your side take your time be sure of what you’re doing
  10. abyliks
    abyliks Road Train Member
    4,091
    9,628
    May 2, 2010
    ludlow MA
    Don’t move the trailer until it is all the way up, atleast when starting out, as you get experience you can decide if you want to walk the trailer instead of the truck and know the load is out of the nose
  11. blade
    881
    647
    Jan 30, 2009
    Some where, Mo
    Unfortunately my first couple of weeks I delivered to a place that was inside so I had to jackknife into the bin and walk the trailer to me wouldn’t do it on all loads #### sure wouldn’t in the winter.
