eng fan
Discussion in 'Volvo Forum' started by mhale0312, Jan 29, 2014.
  1. mhale0312
    mhale0312 Bobtail Member
    11
    Jan 20, 2014
    Volvo d16 fan runs constantly, have 12v at sol, eng ecm controls ground? not sure what ecm pin contols ground, is there a common prob? help!
  3. Powder Joints
    7,980
    8,373
    Sep 25, 2007
    Rosamond, SoCal
    unplug it under the hood, probably an airline controlling it, maybe a bad valve/solenoid
  4. markster1957
    markster1957 Light Load Member
    65
    22
    Jan 21, 2014
    boise id
    Not knowing if your truck has the solenoid in the engine area or you might have the solenoid pack back by the trans the test you can do with out looking at it is unplug the air line off the fan hub and apply air to it , in most cases its the fan that has failed , if you apply air to it and it does not release then replace it , if you have the solenoid under the steering shaft on the fire wall make sure you them together good luck ,****note do you know if its elec control or air controlled , what I mean does it have a air to it or just wires
  5. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    If it's very cold out -5+ then wait to see if it works normal in warmer weather. Mine hates the cold and was just put on two months ago.
  6. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    If you have been running the defroster(I hope you have in this weather) then it sounds like the high pressure switch on the A/C compressor took a dump. Try unplugging that, and someone with more Volvo knowledge than me can tell you if you need to jump the 2 terminals on the connector to turn it off. Completely disabling the fan even in this weather isn't a good idea in my opinion. Just my $0.02...
  7. mhale0312
    11
    Jan 20, 2014
    thanks guys for the quick response, this problem is deeper than the fan air sol, I will try the a/c high press switch before I dive in
  8. mhale0312
    11
    Jan 20, 2014
    open wires in harness, right firewall area for a/c switch
    QUALITYTRUCK Thanks this.
