engine break problem
Discussion in 'Experienced Truckers' Advice' started by johnwayne187, Jun 18, 2017.
  1. Allow Me.
    10,766
    12,579
    May 28, 2009
    Rancho Mirage, Ca.
    in a perfect world, you would descend the grade without applying the brakes using only the jake (engine brake) to hold it back, right ? The fact that you were smokin' the tandems means you were applying the brakes, which is fine if you needed to. I'm guessing you could have been in a lower gear.
    johnwayne187 Thanks this.
  3. johnwayne187
    johnwayne187 Medium Load Member
    327
    117
    Aug 6, 2016
    i was doing sumthin wrong the whole time, i wasnt using the engine break i was using sumthin else the whole time. thats why there was smoke, i just look at the online driver manual. i hope nuthin is damaged
  4. johnwayne187
    327
    117
    Aug 6, 2016
    the moment i saw smoke, i pulled over to the closest chain up area lane as possible to cool down the brakes. everything is fine now, i hope
  5. johnwayne187
    327
    117
    Aug 6, 2016
    the truck they assigned me with had no low beam headlights, i drove the whole night not knowing there wasnt no headlights. thought the guys at the shop checked everyting and was ready to go. which wasnt the case, so i'm hours late on my load to california. i had gotten the lights replaced earlier yesterday. more than likely ill be doing swap
  6. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    Seriously wtf. Pre trip much?
    Boattlebot, Joetro, sawmill and 10 others Thank this.
  7. johnwayne187
    327
    117
    Aug 6, 2016
    dude i didnt kno till the last minute, its not my fault
  8. driverdriver
    4,254
    5,284
    May 30, 2011
    Huh?
    AModelCat Thanks this.
  9. johnwayne187
    327
    117
    Aug 6, 2016
    nvm
  10. driverdriver
    4,254
    5,284
    May 30, 2011
    What do you mean , you didn't know till the last minute?
  11. johnwayne187
    327
    117
    Aug 6, 2016
    fuse blew out, tht was the guys fault at the yard for not fixing the lowbeam headlight problem. i thought it was a minor problem thts why i didnt took it seriously
