Engine derated no codes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by EWV, Dec 14, 2019.
  1. EWV
    EWV Light Load Member
    80
    27
    Mar 22, 2016
    Hi everyone needing some brain storming ideas please.
    2006 kw w900l cat c15 accert
    Check engine light came on with flash code 55...i know i know i know its a no code no issue code BUT this engine has derated and i cant get more than 35 boost out if it now at the most.
    Usually if i get a 55 code the coolant might of dipped a bit low etc..ive checked all the usual suspects for that and it all looks good and i know wouldnt derate it anyway.
    So just wondered if anyone else had run into this issue?
    Going to try find a shop 2moro that can put the computer on it for any hidden codes.
    Thanks
  3. EWV
    80
    27
    Mar 22, 2016
    Update edit
    The check engine light went out whilst i was driving and the boost returned to normal - 45 / 50.
    Then i stopped and high idled due to temp for my 30 min break. As i took off the check engine light came back on and boost restricted again but only for about 3 mins then the light went off and boost returned again.
    Stopped again for 15mins and as soon as i took off check engine light back on and boost restricted but this time it is didnt go out.
    Should i be looking for a wire thats rubbing / is it just having a brain fart becoz ive had -22c / -7f or is there a looming engine or turbo issue??
    Thanks
  4. pushbroom
    pushbroom Road Train Member
    1,788
    7,393
    Sep 1, 2012
    Flash code only displays active codes. It might have inactive codes that only become active when driving. Needs to get on a laptop
    Heavyd, AModelCat, EWV and 1 other person Thank this.
  5. EWV
    80
    27
    Mar 22, 2016
    Ok thanks..was thinking we need to get it hooked up
  6. AModelCat
    164,211
    ECM will save every code that has become active since the last time they were cleared. Get it on ET and you'll see which component is suspect.
    Goodysnap and EWV Thank this.
  7. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    When you stop ck level in rad and fuel filter if it has a see thru type filter
    EWV Thanks this.
  8. EWV
    80
    27
    Mar 22, 2016
    Yea already done the rad. The fuel filter isnt a clear one...maybe chsnge thr filters coz it got so cold?
    Will put the computer on it 1st tho.
    Thanks
