Engine fan size vs cooling ability
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Big Road Skateboard, Jul 27, 2021.
  1. Big Road Skateboard
    6,988
    39,487
    May 2, 2021
    Anybody ever installed a larger, more blades, or wider blade fan? It's well into the 100's today her e in Wyoming and South Dakota, and I'm having to back out of it on some hills.
    If so, how much effect did it have.
    Thanks guys
  3. Arctic_fox
    4,470
    25,139
    Sep 16, 2016
    It CAN have an effect but it will be minimal due to how the radator works. Usually your better off getting a thicker and/longer/wider radator depending on how much room you have and where it is. More surface area means more coolant getting cooled at a time means easier to manage temps.
    A really basic breakdown of whats going on but good enough for discusion.
    Big Road Skateboard Thanks this.
  4. TJB15
    TJB15 Light Load Member
    67
    115
    Apr 29, 2020
    Once changed fan from steel to plastic on an old '92 9300 410hp n14 stc motor (helped some) however the crossflow radiators in the old internationals really seemed to be the bigger issue.
    Oxbow Thanks this.
  5. lester
    2,955
    8,062
    Jan 2, 2012
    NW, Iowa
    What truck and engine you got?
    I know some guys switch their older cats to an acert fan with good results. More blades I think and moves more air
    Oxbow Thanks this.
  6. Big Road Skateboard
    6,988
    39,487
    May 2, 2021
    92 Volvo with a 11.1 DDEC II. I've tuned it pretty hot, so heat is gonna happen, was just thinking of a way to increase flow.
    It has a new 4 core and new water pump.
    Cooling has definitely improved since replacement, but today's heat caused some issues.
  7. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    How much of a gap do you have from the fan to the shroud?
    The wider the gap the less efficient it will be
    Goodysnap Thanks this.
  8. Big Road Skateboard
    6,988
    39,487
    May 2, 2021
    I assume you're speaking side to side? The standard 2ish inches you get with the correct belts, all the way around, so a slightly larger diameter fan is possible.
    I also have some depth to work with there, 3-4 inches, so a wider blade would be possible too.
    I just didn't want to chase that rabbit if the difference was negligible.
